OSPF lab help.
Lijesh NC
I am trying to set up an OSPF lab for running 5 Modes of ospf Operation.I am confused how can i make a framerelay cloud to run this.Can some some help me to achive this.
Thanks in advice
Lijesh
7 Replies 7
jimmysands73_2
Level 5
Level 5
When I was doing my NetAcad and trying to get ospf working over fr, I had to use the commad ip ospf network broadcast before my ospf routes were sent. I think. Eventually I got the FR working with OSPF though.
If you would post alittle bit more info, I'd be happy to look it over.
Reza Sharifi
I am not sure if I understand the question
Are you trying to build a frame relay cloud?
If yes, then you need a router like a Cisco 2522 as your frame relay switch.
Then you connect all your serial cables from all the other routers to this
Switch/router to simulate frame relay
Reza
hi sharif,
Thanks for the reply ..yes you are right . i am trying to build a frame relay cloud ..can i know the config (frame-relay cloud )can i achive this by dinamips ..
hitesh_patel
Hi Lijesh,
you need any low end cisco router with four or more serial interfaces to fit to your topology. You can have 2522 with 10 serial interfaces or can have any 2600 with NM-4AS or NM-8AS card. The rest is easy to configure it as frame relay switch. Here is the link which shows how to configure.
http://www.thebryantadvantage.com/Frame%20Relay%20Switch.htm
Hitesh Patel
Hi Hitesh,
Thanks for the reply this was what i was loolkig for.will i b able to achive using dinamips ... any way i will give an try and let you know the status ...
lijesh
Hi hithesh,
Thank you so much i had tried (http://www.thebryantadvantage.com/Frame%20Relay%20Switch.htm ) and was able to do ..but can i run ospf on this topology if so what all changes need to be done in FR Swtich/Routers.Kindly help ..
Thanks in advance
Lijesh NC
If you were trying to do this for a class, I would suggest you try it on your own, then post what issues you are having. For starters:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009470d.shtml
http://supportwiki.cisco.com/ViewWiki/index.php/How_to_configure_OSPF_over_Frame_Relay
