OSPF load balancing with ADSL
sabeshkhan
I have 2 ADSL links and I need to implement a load balancing system between these links.
Does any one know how to do this?
blau grana
Level 7
Level 7
Can you describe your topology? These links will be transport links or they will be used to connect some branch to your network?
If second scenario is correct, then OSPF will instal subnets to routing table via both links if you configure same OSPF cost on both links.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
I have to ADSL links which is use to internet (links). I have connected those links with two cisco 871w routers (one for each link) and then I gave a connection between the router and the switch. In this case I can use only one link at a time I need to use both links so I thought to use a cisco 1841 router inbetween the 871 and the switch. Is this possible with OSPF please help me
Thank you
Hello
LB between two ISP's is very common and indeed recommended so providing we have enough information we should be able to assist you.
This topology isn't clear - you have mentioned 3 routers and a switch -Can you post a topology of this setup and define any routing protocols /static's routes.and ip addressing.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
