Bookmark
Subscribe
5357
OSPF Loading/Full loop
raphaeloester
I'm having a bit of a trouble trying to configure an OSPF setup here on packet tracer. You can find my topology in the attachement Capture.PNG.
What's happening is that my "BERLIN" labelled router just doesn't get any of the routes it's supposed to via OSPF :
Router#show ip route
!!!snip!!!
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C 10.10.6.0/24 is directly connected, GigabitEthernet0/1
L 10.10.6.254/32 is directly connected, GigabitEthernet0/1
C 10.10.100.0/28 is directly connected, GigabitEthernet0/0
L 10.10.100.6/32 is directly connected, GigabitEthernet0/0
The wierd part is that i constantly get logging messages on this router, like so :
00:23:55: %OSPF-5-ADJCHG: Process 10, Nbr 1.1.1.1 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:05: %OSPF-5-ADJCHG: Process 10, Nbr 1.1.1.1 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:15: %OSPF-5-ADJCHG: Process 10, Nbr 1.1.1.1 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:25: %OSPF-5-ADJCHG: Process 10, Nbr 1.1.1.1 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:35: %OSPF-5-ADJCHG: Process 10, Nbr 2.2.2.2 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:45: %OSPF-5-ADJCHG: Process 10, Nbr 2.2.2.2 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:50: %OSPF-5-ADJCHG: Process 10, Nbr 2.2.2.2 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
00:24:55: %OSPF-5-ADJCHG: Process 10, Nbr 2.2.2.2 on GigabitEthernet0/0 from LOADING to FULL, Loading Done
It's just alternating between 2.2.2.2 ( MADRID ) and 1.1.1.1 ( LISBOA )
Although my configuration seems fine :
BERLIN'S CONFIGURATION :
Current configuration : 770 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15244MM2
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 10.10.100.6 255.255.255.240
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.6.254 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 6.6.6.6
log-adjacency-changes
network 10.10.6.0 0.0.0.255 area 0
network 10.10.100.0 0.0.0.15 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Here's LISBOA'S configuration, which seems to be chosent as DR.
Current configuration : 994 bytes
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX152425E6
ip address 10.10.1.254 255.255.255.0
duplex auto
speed auto
ip address 10.10.100.2 255.255.255.240
duplex auto
speed auto
interface Serial0/0/0
ip address 10.10.100.17 255.255.255.252
interface Serial0/0/1
ip address 10.10.100.21 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 1.1.1.1
network 10.10.1.0 0.0.0.255 area 0
network 10.10.100.16 0.0.0.3 area 0
network 10.10.100.20 0.0.0.3 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Finally, MADRID :
Router#show run
Building configuration...
Current configuration : 977 bytes
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524DL27
duplex auto
speed auto
ip address 10.10.2.254 255.255.255.0
duplex auto
speed auto
ip address 10.10.100.18 255.255.255.252
clock rate 2000000
ip address 10.10.100.25 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 2.2.2.2
network 10.10.2.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Thanks for your help !
now I see two 10.10.100.2 ip, please can correct it and check again.
5 Replies 5
can I see show ip interface brief for Berlin branch ?
I see double IP address 10.10.100.6 config in to two routers this is issue I think, please change one of them.
My mistake, i pasted twice the same configuration when I created the post. Now it's edited. Here is the IP interface brief for Berlin :
GigabitEthernet0/0 10.10.100.6 YES manual up up
GigabitEthernet0/1 10.10.6.254 YES manual up up
Vlan1 unassigned YES unset administratively down down
Oh my god... I can't believe i banged my head against the wall for two days because of a simple ip address duplicate... Thanks for your response anyway.
Conclusion : weird loops like this may be caused by two routers having the same IP address on the same subnetwork. Hope it can help someone to know this
You are So So Welcome
