ospf max-lsa default value
yaroneis
I am looking for the ospf 'max-lsa' default value, and cannot find it.
Can anyone help on this one?
Thank, Yaron
Hello Yaron,
here is the link to the relevant command, it lists the defaults, hope that's what you are looking for...
max-lsa
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_osph.htm#wp1092530
GP
Yep, thanks.
"The number of nonself-generated LSAs that an OSPF routing process can keep in the OSPF LSDB is not limited.", and i missed the 'not limited'... :-)
How would you determine the maximum-number? Is there a rule of thumb?
