OSPF multi area adjacency
sachin30720041
I am trying to understand multi-area adjacency.
r1----area0----r2
area0.              area0
r3-----area1--r4
R3's loopback:- 3.3..3.3 in area0
r4's loopback :-4.4.4.4.4 in area0
r3's routing table points to r1 to go to r4's loopback(4.4.4.4). while low cost path is available but inter-area route. So I configured multi-area adjacency on r3 and r4.
r3's gi0/0 pointing towards r4.
int gi0/0
ip ospf network point-to-point
ip ospf 1 area 1
ip ospf multi-area 1
r4's gi0/0 pointing towards r3.
int gi0/0
ip ospf 1 area 1
But still in R3's routing points to R1 for 4.4.4.4.
R3's routing table should point to r4. correct?
Is there any problem with the config?
Sachin
Giuseppe Larosa
Hello @sachin30720041 ,
you have attempted to configure multi area adjacency on link between R3 and R4.
have a look at the folowing document
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/118879-configure-ospf-00.html#anc15
Compare your configuration with the following one:
interface Ethernet0/1
ip address 192.168.23.2 255.255.255.0
ip ospf multi-area 99
ip ospf 1 area 0
end
Your configuration should be:
nt gi0/0
ip ospf 1 area 0
on both routers
With your current config there is no multi area the link is only in area 1 and as noted by other O routes are preferred over O IA regarldess of metric.
Hope to help
Giuseppe
balaji.bandi
You can view the OSPF database and routing output why that chose over the connected interface.
here is a good example and explanation :
https://blog.ine.com/2011/04/04/understanding-ospf-external-route-path-selection
BB
pman
in your case: R3 learned 4.4.4.4 through Intra-Area (O) (R1>R2>R4)
ospf path selection rules:
Intra-Area (O)
Inter-Area (O IA)
External Type 1 (E1)
External Type 2 (E2)
NSSA Type 1 (N1)
NSSA Type 2 (N2)
Inter-Area (O IA) IA is less preferred than Intra-Area (O) so I think R3 would prefer an inrta-area (O) path over an inter-Area (O IA)
Giuseppe Larosa
ip ospf 1 area 0
end
nt gi0/0
ip ospf 1 area 0
on both routers
Hope to help
Giuseppe
