ospf multi-area
Hello Everyone, I am trying to realize a multi-area ospf lab as shown in shared diagram. I am able to ping 10.10.60.1 (from R5) but getting no reply from PC1 i.e 10.10.60.100. Router configurations are attached with the post. Please help
3 Accepted Solutions
Reza Sharifi
Can you ping 10.10.60.100 from R1? If not, make sure the PC does not have a firewall software blocking ICMP.
Julio E. Moisa
Is the PC properly configured? it has the default gateway 10.10.60.1? Is the PC able to ping the gateway?
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I recreated your setup in GNS3, it works as designed. To be sure that the PC gets the appropriate IP address, configure a DHCP pool on R1:
ip dhcp excluded-address 10.10.60.1
ip dhcp pool LAN
network 10.10.60.0 255.255.255.0
default-router 10.10.60.1
lease 3
Reza Sharifi
Julio E. Moisa
Hope it is useful
ip dhcp pool LAN
lease 3
Thanks for advisories. I was using an Ubuntu docker host as PC1. Replaced it with a VPC, its working
(Y)
