ospf multi-area
Telim
Hi Guys, I'm trying to do the Multi-Area OSPF in 5 routers.
It the first time that I do that. So, I don't know what am I doing wrong can someone help me?
Thanks a lot in advance
Topology
Build the following network. (multi-area OSPF, VLANs)
5 Routers with serial ports
2 Switches (switch attached to the last router on each leg)
1 end device attached to each switch
Network Leg A:
  10.10.10.0/25; network host requirement is 100 devices
  VLAN 100
Network Leg B:
172.16.20.0/26; network host requirement is 50 devices
VLAN 200
Configure multi-area OSPF and ping successfully from Leg A to Leg B.
Enable to pin from Pc1 to Router 1, Pc 2 to Router 2 and between the routers but I CANNOT ping between the pcs that is what I need to do.
Deepak Kumar
This is a duplicate post but here I am also going to attach a working lab.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Hello
Just like to add you can even go a step furhter as both areas are stubs, you can make them so.
router 2
router ospf 1
area 1 stub no-summary
router 1
router ospf 1
area 1 stub
router 4
router ospf 1
area 2 stub no-summary
router 5
router ospf 1
area 2 stub
Kind Regards
Paul
Thank you, Paul, and for the extra input. It is really helpful.
