OSPF multiple separate processes
syntaxmonster
Hi to all,
well my question sounds kind of weird. So let me go to the point.
Cisco doesn't recommend to use multiple opsf processes on the same router although this is possible.
We have in our network a working multiple area design with route summarization, static routes, stub areas etc etc.
Now, we need to build another separate network with a routing protocol (OSPF) on the same router.
Separate means no route exchange between these two ospf processes.
It also has to be possible to insert static routes which aply once for one process and another static route for only the other process.
Can this approach be reached with OSPF?
Happy New Year! :)
Hello Christian,
you cannot specify an ospf process in a static route but you can choice what static routes are redistributed into each OSPF process
router ospf 1
redistribute static subnets route-map static_to_proc1
router ospf 2
redistribute static subnets route-map static_to_proc2
you can create the static routes with a route tag
ip route 10.10.1.0 255.255.255.0 172.20.5.30 tag 33
ip route 10.10.2.0 255.255.255.0 172.20.5.35 tag 88
then the route-maps can just match the route-tags:
route-map static_to_proc1 permit 10
match tag 33
route-map static_to_proc2 permit 10
match tag 88
in this way the first is only redistributed into ospf 1 the second static route only into process 2
Hope to help
Giuseppe
7 Replies 7
MATTHEW BECK
Hello and Happy New Year!
Two OSPF processes on the same box don't talk to each other unless you redistribute between them. But both processes will put routes into the single route table on the box. Adding static routes will also put routes into the single route table. All routing process on a box (OSPF 1, 2, Static, whatever) create one route table. The box then forwards traffic based on all the inputs of all the routing protocols. (Hence administrative distance to prioritize protocols) And keep in mind, you cannot run two instances of OSPF on the same interface either. I'm not sure if your design would require this, but it doesn't work.
I hope this helps.
Matt
Edison Ortiz
Matt hit it right on the head.
In addition to his post, Cisco does not recommend having multiple OSPF routing process due to the added CPU overhead. OSPF (one process) is CPU intensive as is - imagine having 2 OSPF process calculating SPFs?
If you want separate routing table, you should look into VRF-Lite or full blown MPLS.
HTH,
__
Edison.
Giuseppe Larosa
Hello Christian,
you can configure two OSPF processes on the same box.
As Matthew and Edison have pointed out if you need a real separation, both on the signalling and forwarding plane, you need to implement VRF lite or MPLS VPNs.
If instead you want to keep separated the routing domains but you want to have some traffic going between them just define two OSPF router processes on the global routing table (no VRF involved).
Note: in this second case I recommend to design the OSPF areas with different area-id in the two routing instances: you are allowed to use a non zero area to implement a single area OSPF domain.
The reason for this is to provide a security mechanism to avoid unwanted OSPF adjacencies to be formed by accident.
OSPF v2 hellos keep the area ID and area flags but not the OSPF process-id for this reason if you put the same
network x.x.x.x area y
under both routing processes the router will be in trouble and will not advertise the network in either process it cannot decide to what process a link belongs.
So using different area numbers protect you from this possible mistake too.
Hope to help
Giuseppe
Christian
In your original post you stated these as the requirements:
If you need a separate network, running a dynamic routing protocol, with no exchange of routing information with the original network, then it seems to me that 2 OSPF processes is just what you need. Be aware of the restriction that an interface can belong only to a single OSPF process. But if the 2 networks are truly independent I would assume that you do not have any interface that needs to belong to both.
If you need some static route redistributed into one OSPF and some other static route redistributed into the other OSPF then you need to configure the redistribution of static into each OSPF with a distribute list or with a route map that will control redistribution and allow only the desired static to redistribute into each OSPF process.
If we knew more about your environment and the requirements, there might be alternatives we could consider such as VRF lite that might work for you. But based on your original post I believe that multiple OSPF processes can work for you.
Rick
Rick
thank you all for your answers.
Matt and Rick: no, those OSPF processes will run on different interfaces so there is no problem with that.
My main concern is the fact, that every OSPF process is using the same static routes (as Matt said) but this is exactly what i want to avoid.
I must be able to assign static routes to different OSPF processes. For example:
ip route 10.10.1.0 255.255.255.0 172.20.5.30 ospf id 100
ip route 10.10.2.0 255.255.255.0 172.20.5.35 ospf id 200
Have a nice day,
Christian
Hello Christian,
router ospf 1
router ospf 2
match tag 33
match tag 88
Hope to help
Giuseppe
Giuseppe,
this is exactly what i wanted to do. Great! Thank you to all for your helpful replies.
Christian
