OSPF neighbor question
bellocarico
The OSPF neighbor command permits to create adjacencies with neighbor using unicast instead of the defaul multicast.
I'm juts wondering if it's possible/suggested to create adjacencies with neighbors in different subnets (one or more hops away) on the same stile eBGP does.
Thanks to read
Harold Ritter
Note that OSPF messages are carried in IP headers with a TTL of 1. The only exception is OSPF virtual links as Richard mentioned.
Hope this helps,
Richard Burts
Stefano
No it is not possible or suggested to try to establish neighbor relationship with routers one or more hops away. EBGP does have a concept of multi-hop neighbors but OSPF does not.
The one exception to wht I have just said is the OSPF concept of virtual links. With virtual link the OSPF router does exchange updates with a router that is multiple hops away.
Rick
Rick
Harold Ritter
Hope this helps,
nockor01
you can setup a gre tunnel between routers and put the tunnel network in ospf
for it to work, the tunnel destination on each router must be reachable without ospf.. (ie. static route)
rob nockowitz
ccie #15410
