I have two location A and B and two internet service provider. For one isp tunnel is working fine and having ospf neighborship. For other isp, ospf neighborship is not firming. I am able to ping both locations from ISP IPs. I checked ospf parameters they are same on both location. Let me know if any other information need for more details. Appreciate any kind of help.
Location A
Tunnel configuration
interface Tunnel5
description tunnel to B location
bandwidth 50000
ip address 10.10.10.1 255.255.255.252
no ip redirects
ip mtu 1440
ip tcp adjust-mss 1400
ip ospf message-digest-key 1 md5 tunnelB
ip ospf cost 10
tunnel source GigabitEthernet0/0/1(2.2.2.2)
tunnel destination 1.1.1.1
tunnel key 5
tunnel vrf hello
tunnel protection ipsec profile P1 shared
end
OSPF
router ospf 1
area 0 authentication message-digest
network 10.10.10.0 0.0.0.3 area 0
sh ip ospf interface tunnel5
Tunnel5 is up, line protocol is down
Internet Address 10.10.10.1/30, Interface ID 75, Area 0
Attached via Network Statement
Process ID 1, Router ID 10.10.120.10, Network Type POINT_TO_POINT, Cost: 10
Topology-MTID Cost Disabled Shutdown Topology Name
0 10 no no Base
Transmit Delay is 1 sec, State DOWN
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Location B
interface Tunnel5
description tunnel to A location
bandwidth 50000
ip address 10.10.10.2 255.255.255.252
no ip redirects
ip mtu 1440
ip ospf cost 10
tunnel source source GigabitEthernet0/0/2(1.1.1.1)
tunnel destination 2.2.2.2
tunnel key 5
tunnel vrf bye
end
OSPF
router ospf 1
Internet Address 10.10.10.2/30, Interface ID 26, Area 0
Process ID 1, Router ID 10.10.30.15, Network Type POINT_TO_POINT, Cost: 10
0 10 no no Base
Mark
已解决! 转到解答。
On tunnels using VTI like this a tunnel up line protocol down is frequently an indication that crypto negotiation was not successful. Can you post the output of
show crypto ipsec sa
from both routers?
A couple notes/questions:
Does the tunnel work without the IPSec/OSPF applied?
If so just add the OSPF back in.
If it works it could be something with the IPSec tunnel. Also, I'm not sure the exact amount but adding an IPSec configuration on top of a GRE tunnel adds more headers I believe. You could try lowering the MTU to 1400 and the TCP adjust-mss to 1360
COuld you also show the out put of the
debug ip ospf packets
and the
debug crypto ipsec
commands
-David
Hi David,
Thank you for your reply. For other ISP, i have same configuration with MTU and and TCP adjust-mss. It is working good. Cant do debug on production router. Last time i did debug and it was hangup. I had to go to datacenter for reboot it. any thing else can i provide you?
Mark
Understood.
OK on both routers can you do a:
show ip protocols
show ip interface brief
show ip route
Also, do you have the excact same IPSec profile on the working routers?
Another question. Can you do a terminal monitor command to see error messages on your logged in session to see if OSPF is trying to form an adjacency and getting messages? Usually you will see output of neighbor ship trying to form but not establishing.
Hello
Can both location reach each other source/destination addressing?
Are they in the correct vrf?
Append the same vrf on the tunnels and possibly
capability vrf-lite
to the ospf stanza
interface Tunnel5
tunnel source source GigabitEthernet0/0/2(1.1.1.1 < is this the correct interface
tunnel vrf hello < ------different vrf
interface Tunnel5
tunnel source GigabitEthernet0/0/1(2.2.2.2)< is this the correct interface
tunnel vrf bye < ------different vrf
Possible going forward append this also
router ospf xx
capability vrf-lite
from both routers?
Hello
As stated the tunnels are in different vrfs, So remove them from the tunnels and test otherwise make sure the source and transit interface are also in the same vrf rib table.
Mark
You are welcome. I am glad that my suggestion pointed you toward the solution. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Thank you @paul driver @MHM Cisco World @David Ruess . Issue was with crypto key. I fixed it. once tunnel became up. ospf neighborship automatically Built up. Thank you for your effort and time. Appreciate it.
