OSPF NSSA type 7 to type 5 translation
RanilG
Level 3
Level 3
NSSA area border router is supposed to translate LSAs from type 7 to type 5.
On the other hand only ASBR can generate type 5 LSA. In the case of NSSA, is it correct to assume that NSSA ABR must also necessarily be an ASBR?
rsg.
6 Replies 6
Jon Marshall
rsg.
No it isn't ie.
R1 (area0) -> (area0) R2 (area2 - NSSA) -> (area2 - NSSA) R3 -> R4
In the above R3 & R4 are running EIGRP and R3 is advertising the EIGRP routes into area2.
R2 is the NSSA ABR and R3 is the NSSA ASBR.
The ABSR in an NSSA area will advertise external LSAs as type 7 as you say. These type 7s are blocked at the ABR ie. they are not advertised out of the nssa. But if the ASBR sets the P-bit in the LSA the ABR will then advertise the external LSA as a type 5 beyond the NSSA. However this doesn't mean the ABR is an ASBR because the definition of an ASBR is that it receives and advertises routes learnt from another routing protocol and clearly this does not apply to an NSSA ABR as in the example above.
Jon
Thanks for the reply.
RFC 1587 points out that " All NSSA area    border routers must also be AS boundary routers since they all must    have the capability of translating a type-7 LSAs into a type-5 LSAs".
// See section 3.4   Originating Type-7 LSAs //
It sounds a  bit contradictory to me. Could you clarify this point as well please.
Cheers,
rsg.
Hi Rsg,
I tried capturing OSPF packet and can see that NSSA ABR sets both B bit and E bit in Router LSA. So it means that ABR connected to NSSA will act as both ABR/ASBR.
"show ip ospf border-router" output also seems to shows it as both ABR/ASBR.
HTH,
Nagendra
Thanks Nagendra for confirmation of this point. Jon/Marikakis: thanks for your comments as well.
So it looks like that the NSSA ABR also acts as an ASBR. However, I couldn't find this information in any document other than the RFC 1587, which made me post this query for your valued opinions.
Of course, I had no intentions of letting any one into any sort of a trap and the sole objective was to get my doubts clarified. In my book nitpicking is off-topic.
Cheers!
Through i have nothing new to add just thought to ask a question,  ABR who floods LSA type 5 would also be called as ASBR as they are also forwarding/generating LSA type 5.
Router who generated LSA type 7 is ASBR as LSA type 7 can ONLY be flooded to that area and LSA type 5 can be flooded to all areas. So ABR is just changing it from LSA type 7 to 5.
According to RFC 2328:
"3.3.  Classification of routers
AS boundary routers
A router that exchanges routing information with routers belonging to other Autonomous Systems.  Such a router advertises AS external routing information throughout the Autonomous System."
"12.1.5.  Advertising Router
This field specifies the OSPF Router ID of the LSA's originator... AS-external-LSAs are originated by AS boundary routers."
Note that the last sentence above can kind of serve as a reverse definition of an ASBR from the LSAs it originates.
Similar reasoning can be found in other places of RFC 2328 e.g.:
"12.4.4.  AS-external-LSAs
AS-external-LSAs describe routes to destinations external to the Autonomous System... AS-external-LSAs are originated by AS boundary routers."
"A.4.5 AS-external-LSAs
AS-external-LSAs are the Type 5 LSAs.  These LSAs are originated by AS boundary routers, and describe destinations external to the AS."
Now, according to RFC 1587 you mentioned (keep reading ):
"4.1 Translating Type-7 LSAs Into Type-5 LSAs
...The newly originated type-5 LSAs will describe the same network and have the same network mask, metrics, forwarding address, external route tag and path type as the type-7 LSA. The advertising router field will be the router ID of this area border router."
So, the NSSA ABR is the advertising router of the type-5 LSAs originated due to the type-7-to-type-5 translation process, and is therefore an ASBR. I guess we could view that ABR as representing the external routing information of the NSSA to the rest of the AS.
Had I not read your second post, I would have provided an answer similar to Jon's. Since you had already read the RFC when you opened the thread, perhaps you could have also mentioned it in your original post instead of letting us fall into the trap!
As always, definitions generally tend to be imperfect and if taken very seriously, people can find themselves into a scholastic loop that loops forever. For example, according to the RFC you are reading, if multiple NSSA ABRs exist, one of them performs the translation process, so an NSSA ABR might not also be an ASBR.
This step is performed as part of the NSSA's Dijkstra calculation after type-5 and type-7 routes have been calculated.  If the calculating router is not an area border router this translation algorithm should be skipped.  All reachable area border routers in the NSSA should now be examined noting the one with the highest router ID.  If this router has the highest router ID, it will be the one translating type-7 LSAs into type-5 LSAs for the NSSA, otherwise the translation algorithm should not be performed."
The sentence: "All NSSA area border routers must also be AS boundary routers since they all must have the capability of translating a type-7 LSAs into a type-5 LSAs (see section 3.6 routes for the translation algorithm)." found in the same RFC could therefore be considered inaccurate according to the logic of that same RFC.
If we follow such paths of reasoning, I guess we might find ourselves ready to work in a legal department!
