OSPF Path Selection
Chiranjit Dey
There are 2 paths to destination in an OSPF network. Both paths have equal total path cost. So by default OSPF takes both paths to its routing table. "maximum-paths 1" command is given after that and as its effects only one path is now in the routing table from 2 paths having equal total path costs.
Now which path is taken for the routing table between 2 paths and why?
Philip D'Ath
I don't know the answer - but I expect the last route received (aka the most recent update) to be installed into the routers forwarding table.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From my experience, it appears it's implementation specific (and best avoided [i.e. don't count on observed behavior]).
1001QA.Net
MTU can be used as a tie breaker
