09-24-2019 12:50 AM
any command similar to #sh ip bgp sum for ospf which shows how many prefix recieved from a particular ospf neighboir
Solved! Go to Solution.
09-24-2019 10:27 PM
There is a command series as Show IP OSPF DATABASE. You can visit at https://networklessons.com/ospf/read-ospf-database for more understanding out the database.
09-24-2019 06:15 AM
Try with "Show IP Router OSPF", I am not sure that I got your question correctly or not.
09-24-2019 10:19 AM
my question is ,,, if you type sh ip bgp sum , it will show you how many prefix you recieve from a paticular peer.
sh ip route ospf show all the prefix recieved but i want to show similar result as bgp if you have thousands of it
09-24-2019 04:20 PM
I do not know any specific command to provide you the list of subnets you learned from OSPF neighbors. However, you can see how many subnets you learned from all of your neighbors as far as they made it to the RIB using show ip route summary (or show ip route summary | i ospf)
HTH,
Meheretab
09-24-2019 07:56 PM
thanks for your kind reply
09-24-2019 08:15 PM
No there is no specific command but you can see the database details for the same.
09-24-2019 08:43 PM
thanks deepak ..can you show an example
09-24-2019 10:27 PM
