08-12-2012 08:12 PM - edited 03-04-2019 05:15 PM
I have configured lots of router with OSPF. Most of them working fine, but on some of the routers it's not working. Same commands used except the network address change. I have checked the commands, nothing wrong in commands.
The "sh ip ospf database" command gives the link state of only the same router's database. show ip ospf neighbor gives no data. From where should I start troubleshooting ? Please guide me.
Yours,
Mero
Solved! Go to Solution.
08-12-2012 11:27 PM
Hi Mero,
The fact that the show ip ospf neighbor output is empty is a good indication that there is a problem in basic neighborhood/adjacency establishement. You have to verify the following:
Please keep us informed. Good luck!
Best regards,
Peter
08-13-2012 03:00 AM
Hello Mero,
Please Check the following points if your neighbor relationship is not comming up
1) Check the physical connectivity
2) Check for area no and process has initialize on interface or not ....(command :sh ip ospf int brief )
3) Check for network type (point to point ,point to multipoint ,NBMA etc)....(Command:Sh ip ospf interface )
4) Check for Authentication.(Type of authentication type 0,1,2 need to be on both side,also the authentication key)
5) Check for MTU size on the interface.(Need to be same or else database will not going to be exchange)
6) Check any ACL is present on interface.
7) Check for the Subnets
8) Check for the Area type (Stub,totally stub,nssa,normal area)
9) Check for dead and hello timers both need to same on the both sides
10) Router Id must unique in the your As.
Good commands to verify troubleshooting ospf issue
1) sh ip os int brief
2) sh ip os ne
3) sh ip protocol
4) sh ip ospf database (check for specific type like network,router,external etc )
5) clear ip ospf process (will kill all neighbor in short it will reinitialize process)
If you want to see Ospf adjecency is flapping then use this command under ospf process (ospf log-adjacency-change) ,
Still u will be having problem with full Neighborship use Debug ip ospf adj or packet (Not recommanded in live enviroment)
Also keep in mind that media can have Impact on ospf neighborship (example: In Framerelay broadcast queue packet drops ,you can verify that using command :sh interface ( check for broadcast sent/dropped)
Hop that is informative to you.
Ashish
08-12-2012 11:27 PM
Hi Mero,
Best regards,
Peter
08-13-2012 02:07 AM
Hi Peter,
Thanks for your kind response.
I found one mistake on one of the router and fixed the problem. But in another router I get nothing with the shop io ospf database except it's own loopback data but I can find 4 neighbor detail with INIT/DROTHER state. What to do now ?
Mero
08-13-2012 02:11 AM
Hello Mero,
If you see a neighbor stuck in INIT state then there's a chance there is an ACL on that neighbor's interface that blocks OSPF traffic. Can you check that? If there is an ACL in the in direction on the neighboring router's interface, can you post its contents here? It will be easier to suggest a correction.
Best regards,
Peter
08-13-2012 02:19 AM
Dear Peter,
I have deleted the ACL from ther interface. The router is woking fine with static routing but not working with OSPF.
Mero
08-13-2012 02:24 AM
Mero,
Please do not make extensive configuration changes like removing ACLs. We first have to narrow down the problem and only then make configuration changes. Doing these blind experiments may actually make our situation worse.
So once again - you are telling me that the neighbor whose state is indicated as INIT indeed has an ACL placed in the in direction on the interface towards your router. Please be so kind to post both the configuration of that neigbhor's interface and the ACL itself. If there are any sensitive information like public addresses, you may replace them with "x.x.x.x" but otherwise, do not remove any parts of the configuration.
Thank you!
Best regards,
Peter
08-13-2012 03:00 AM
Hello Mero,
2) sh ip os ne
3) sh ip protocol
Ashish
08-13-2012 08:10 PM
Dear Ashish,
Thanks for your kind reply. The difference I found on the functioning and non-functioning is the state. The state of WAN connectivity is DROTH in functioning and DR in non-functioning, how to correct this one ?
Mero
10-04-2012 01:33 AM
Hey mero ,
Thanks for your reply,
please find the answer for your question
DR is port-based means only for that network segment, a router may be the DR for one area but may not be the DR of another area.
To better manage LSA floods on same network segment, DR is elected.
DRothers will form adjacency with DR and BDR only and DRother is a router that is neither a DR nor a BDR.
DRother routers send hello packet to ALL ospf enable Router using 224.0.0.5 to check the existence of neighbouring OSPF routers.
However update will only be multicast using 224.0.0.6, only DR and BDR will listen to this MC.DR will send update to ALL ospf ROUTERS using 224.0.0.5.DR and BDR also forms adjacency to each other.
Backup Designated Router (BDR) is elected to replace DR during DR fail. Hence DRother routers also form adjacency with BDR.
When OSPF process started, the process will look for existing DR and BDR election
If there’s no DR but there’s a BDR, BDR will be promoted to DR.
During the election process the highest priority router wins the DR
the next highest priority router become BDR,If all routers priority is a tie, then the highest router ID will be the tie-breaker.
i.e could be manually set on the router or highest loopback or up up interface will be the router id for that router
Hop it will help you
Thanks and regards,
Ashish shirkar
