OSPF problem with two ABR
Not applicable
Hi experts,
We have a problem with an OSPF setup on which we see two routers, Pavas and Atenas who are in area 0, and they are ABRs for a router PZ who is in another area 56. The problem we see is that the conection between Pavas and PZ is intended to be a backup, and the connection Atenas-PZ is intended to be the main one. We set up an OSPF cost of 1000 between Pavas and PZ, but still Pavas prefers to send traffic directly to PZ instead of using Atenas.
The problem we have is that PZ does use Atenas as its exit point so we are seeing an assymetric flow on which Pavas sends the traffic directly to PZ and PZ answers back through Atenas.
What we want is to have Pavas sending the traffic to PZ via Atenas.
Configuration:
PZ:
interface Loopback0
description ADMIN
ip address 10.192.9.193 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet0/0
description TO PAVAS
dampening 30 75 2000 240
bandwidth 300000
ip address 10.X.X.62 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf network point-to-point
ip ospf cost 1000
ip ospf mtu-ignore
load-interval 30
carrier-delay msec 0
delay 1000
duplex full
speed 1000
media-type gbic
negotiation auto
interface GigabitEthernet1/0
description To ATENAS
ip address 10.X.X.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
router ospf 1805
router-id 10.192.9.193
log-adjacency-changes
auto-cost reference-bandwidth 100000
timers throttle spf 50 50 5000
timers lsa arrival 15
timers pacing flood 15
redistribute connected subnets
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet1/0
network 10.X.X.2 0.0.0.0 area 56
network 10.X.X.62 0.0.0.0 area 56
network 10.192.9.193 0.0.0.0 area 56
PZ#sh ip route 10.192.0.236
Routing entry for 10.192.0.236/32
  Known via "ospf 1805", distance 110, metric 201, type inter area
  Last update from 10.X.X.1 on GigabitEthernet1/0, 00:55:28 ago
  Routing Descriptor Blocks:
  * 10.X.X.1, from 10.192.0.251, 00:55:28 ago, via GigabitEthernet1/0 // IP of Atenas
      Route metric is 201, traffic share count is 1
ATENAS:
interface Loopback0
description Gestion_Equipo
ip address 10.192.0.251 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
description PAVAS
ip address 10.X.X.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex full
speed 1000
media-type gbic
negotiation auto
description TO PZ
ip address 10.X.X.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
router ospf 1805
router-id 10.192.0.251
network 10.X.X.1 0.0.0.0 area 0
network 10.X.X.1 0.0.0.0 area 56
network 10.192.0.251 0.0.0.0 area 0
Atenas#sh ip route 10.192.9.193
Routing entry for 10.192.9.193/32
  Known via "ospf 1805", distance 110, metric 101, type intra area
  Last update from 10.X.X.2 on GigabitEthernet1/0, 01:02:36 ago
  * 10.X.X.2, from 10.192.9.193, 01:02:36 ago, via GigabitEthernet1/0 // IP of PZ
      Route metric is 101, traffic share count is 1
Atenas#sh ip route 10.192.0.236
  Last update from 10.X.X.2 on GigabitEthernet0/0, 01:02:47 ago
  * 10.X.X.2, from 10.192.0.236, 01:02:47 ago, via GigabitEthernet0/0 // IP of Pavas
Pavas:
interface Loopback0
description ADMIN
ip address 10.192.0.236 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
description TO ATENAS
ip address 10.X.X.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex full
speed 1000
media-type gbic
negotiation auto
description TO PZ
ip address 10.X.X.61 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf cost 1000
ip ospf mtu-ignore
negotiation auto
router ospf 1805
router-id 10.192.0.236
ispf
network 10.x.x.2 0.0.0.0 area 0
network 10.x.x.61 0.0.0.0 area 56
network 10.192.0.236 0.0.0.0 area 0
Pavas#sh ip route 10.192.9.193
  Known via "ospf 1805", distance 110, metric 1001, type intra area
  Last update from 10.x.x.62 on GigabitEthernet1/0, 00:01:03 ago
  * 10.x.x.62, from 10.192.9.193, 00:01:03 ago, via GigabitEthernet1/0 // IP PZ
      Route metric is 1001, traffic share count is 1
Pavas#sh ip route 10.192.0.251
Routing entry for 10.192.0.251/32
  Last update from 10.x.x.1 on GigabitEthernet0/0, 00:01:12 ago
  * 10.x.x.1, from 10.192.0.251, 00:01:12 ago, via GigabitEthernet0/0 // IP Atenas
Any additional information, please request me.
Thanks for you help!
Kenneth Rodriguez
Costa Rica.
6 Replies 6
rais
Level 7
Level 7
If an ABR needs to send traffic to an attached area it will do so without sending traffic to the backbone interface. This traffic becomes intra-area traffic on Pavas and no backbone transit is necessary.
HTH.
Not applicable
I know that, but the connection Pavas-Pz via "Radios" have a bandwidth of 300mbps and via Atenas is of 1gbps, for that reason i want ospf to prefer it...
Kenneth Rodriguez
The essence of the problem is that both ABR see each other only through area 0. To achieve your intention of having a backup path both ABR will need to see each other over a path that is in area 56. The easy way to do this would be to configure a tunnel between them and put the tunnel in area 56.
Rick
Rick
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Both Rais and Rick have identified the problem, i.e. once traffic is on Pavas, traffic to Area 56 will flow out on the interface in that area in preference to even a lower cost Area 0 path.
Rick has also identified the typical solution, provide a better Area 56 "link" between Pavas and Atenas than between Pavas and PZ.
Besides Rick's suggestion of using a tunnel, another possible option might be trunking the Pavas and Atenas link so you can have both a logical Area 0 and Area 56 link across it.
joseph is right
I have performed a small lab in packet tracer and observed below things :
In my topology its working as expected to reach 3.3.3.3 which is in R3 my R1 is taking via Area1 and R2 is taking via Area1.
When i increase the cost of the interface on R2 connecting R3 to 100 the path changes via R1 for 3.3.3.3 in R2.
Below are the output.
Normal working
R2 :
Gateway of last resort is not set
3.0.0.0/32 is subnetted, 1 subnets
O 3.3.3.3 [110/2] via 23.0.0.3, 00:00:14, FastEthernet0/1
C 12.0.0.0/8 is directly connected, FastEthernet0/0
O IA 13.0.0.0/8 [110/2] via 12.0.0.1, 00:19:11, FastEthernet0/0
C 23.0.0.0/8 is directly connected, FastEthernet0/1
Router(config)#interface fa0/1
Router(config-if)#ip ospf cost 100
without clearing the ospf process.
O 3.3.3.3 [110/2] via 23.0.0.3, 00:01:19, FastEthernet0/1
O 13.0.0.0/8 [110/2] via 23.0.0.3, 00:01:19, FastEthernet0/1
after - clear the ospf process.
O IA 3.3.3.3 [110/3] via 12.0.0.1, 00:00:20, FastEthernet0/0
O IA 13.0.0.0/8 [110/2] via 12.0.0.1, 00:00:20, FastEthernet0/0
Router#
Please do not hesitate to click the STAR button if you are satisfied with my answer.
