ospf route descriptor
rajeshk200_2
Hi all,
If we issue 'sh ip route' x.x.x.x on ospf enabled router ..how will you interpret route descriptor block.
eg:
Routing entry for A.A.A.A/28
Known via "ospf 100", distance 110, metric 121, type intra area
Last update from X.X.X.X on Vlan20, 19:51:02 ago
Routing Descriptor Blocks:
x.x.x.x, from y.y.y.y, 19:51:02 ago, via Vlan115
Route metric is 121, traffic share count is 1
I know x is the next hop ip address..wht is 'Y' IP address on the output?
Regards, Rajesh
peterledwidge
y.y.y.y would be the originating device.
For example an edge router
