04-22-2017 08:50 AM - edited 03-05-2019 08:24 AM
I have ospf summarisation as below
Router 0 can still view all the routes in router 2 even after summarised at router 0
04-22-2017 11:26 AM
You presumably mean router 1 can still view all the loopback routes on router 2 ?
If so it because you have the wrong subnet mask in your area range command and are therefore not matching any of the loopback networks.
Jon
04-22-2017 12:03 PM
the mask for the area range is incorrect. You need to use a /19 mask to summarize the three networks:
area 1 range 192.168.0.0 255.255.224.0
04-22-2017 02:06 PM
Hi Jordan
I agree with Jon and Georg, your configuration on Router0 should be:
router ospf 100
network 10.10.10.0 0.0.0.255 area 0
network 30.30.30.0 0.0.0.255 area 1
Router 1 should be the summarized network like an Inter Area network.
O IA 192.168.0.0/19 [110/21] via 10.10.10.1, 00:00:02, FastEthernet0/1
