OSPF Routing Table Refresh Issue!!
Chandra Dimri
Hello Guys,
I am working on below topology and I am facing issues of route refresh in ospf routing table
on both ABR's due to which connectivity to Internet is going down and up.
I am seeking your help to know the issue and help in troubleshooting the issue. Below is the output of routing table (showing route refresh) & negibor detail showing neigbor up since 2 days.
6506(ABR1)---ospf point-point-network----4500X (Area 2)
Back to Back connection
6506(ABR2)---ospf point-point-network----4500X (Area 2)
6506(ABR1)#sh ip route ospf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      192.168.2.0/24 is variably subnetted, 4 subnets, 2 masks
O        192.168.2.4/30
           [110/400] via 192.168.2.2, 00:06:26, GigabitEthernet1/2
O        192.168.2.8/30
           [110/300] via 192.168.2.2, 00:06:26, GigabitEthernet1/2
      192.168.4.0/24 is variably subnetted, 4 subnets, 2 masks
O        192.168.4.4/30
           [110/400] via 192.168.4.2, 00:06:26, GigabitEthernet2/7
O        192.168.4.8/30
           [110/300] via 192.168.4.2, 00:06:26, GigabitEthernet2/7
6506(ABR1)#
6506(ABR1)#sh ip ospf ne detail
Neighbor 192.168.2.5, interface address 192.8.178.4
    In the area 0 via interface Vlan2
    Neighbor priority is 1, State is FULL, 6 state changes
    DR is 192.8.178.3 BDR is 192.8.178.4
    Options is 0x12 in Hello (E-bit, L-bit)
    Options is 0x52 in DBD (E-bit, L-bit, O-bit)
    LLS Options is 0x1 (LR)
    Dead timer due in 00:00:36
    Neighbor is up for 2d04h
    Index 1/2, retransmission queue length 0, number of retransmission 0
    First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
    Last retransmission scan length is 0, maximum is 0
    Last retransmission scan time is 0 msec, maximum is 0 msec
Neighbor 192.168.2.9, interface address 192.168.2.2
    In the area 2 via interface GigabitEthernet1/2
    Neighbor priority is 0, State is FULL, 6 state changes
    DR is 0.0.0.0 BDR is 0.0.0.0
    Dead timer due in 00:00:39
    Index 1/1, retransmission queue length 0, number of retransmission 0
Neighbor 192.168.4.2, interface address 192.168.4.2
    In the area 4 via interface GigabitEthernet2/7
    Dead timer due in 00:00:35
    Neighbor is up for 2d01h
    Index 1/3, retransmission queue length 0, number of retransmission 0
6506(ABR1)#
6506(ABR2)#sh ip ospf ne de
Neighbor 192.168.2.1, interface address 192.8.178.3
    Dead timer due in 00:00:32
Neighbor 192.168.2.10, interface address 192.168.2.6
Neighbor 192.168.4.6, interface address 192.168.4.6
    In the area 4 via interface GigabitEthernet1/8
    Dead timer due in 00:00:31
6506(ABR2)#
6506(ABR2)#sh ip route ospf
O        192.168.2.0/30
           [110/400] via 192.168.2.6, 00:04:50, GigabitEthernet1/2
O        192.168.2.8/30
           [110/300] via 192.168.2.6, 00:04:50, GigabitEthernet1/2
O        192.168.4.0/30
           [110/400] via 192.168.4.6, 00:04:50, GigabitEthernet1/8
O        192.168.4.8/30
           [110/300] via 192.168.4.6, 00:04:50, GigabitEthernet1/8
6506(ABR2)#
5 Replies 5
Rolf Fischer
Level 9
Level 9
there seems to be another (perhaps unwanted?) adjacency between the 4500X's via network 192.168.2.8/30.
The routes you've posted were leared via that connection (the intra-area path through area 2 is always prefered over the inter-area path through the backbone).
So maybe you should check if that adjacency looks stable as well.
I also noticed that the RIDs are the physical interface IP addresses. Did you configure the RIDs with the router-id command? If not, using IP-addresses of loopback interfaces as RID or using the router-id command would be a recommended improvement.
Rolf
Hi Rolf,
4500X are also ospf neigbor back to back ove vlan 20 (192.168.2.8/30) & neighborship between them is stable up since 2 days. I haven't configure the router-d command till yet but will do the same, meanwhile I am just wandering what could be the issue which is causing route-refresh. Links are also stable since 2 days and Neigborship is all well stable since 2 days too.
Good morning,
I guess the route refreshs are caused by SPF algorithm re-runs, probably because of a flapping link (this can be a passive interface as well).
In the area sections of "show ip ospf" you can see how often and when the SPFs were executed the last time.
The "Age" column of "show ip ospf database" can be useful to identify the flapping link.
Rolf
Good Morning Rolf,
As per the logs on 6500 (ABR's) I don't see any logs of interface going down but yes its shows OSPF going down and loading  for AREA 2 & AREA 4 Neighbors. Connectivity is on fiber (SM Mode Fiber) and for the links I dont see any links going down or up. Below is the output for SPF --
6500(ABR1)#sh ip ospf statistics detail
            OSPF Router with ID (192.168.2.1) (Process ID 50)
  Area 0: SPF algorithm executed 12 times
SPF 3 executed 2d05h ago, SPF type Full
  SPF calculation time (in msec):
  SPT    Intra  D-Intr Summ   D-Summ Ext7   D-Ext7 Total
  0      0      0      0      0      0      0      0
  LSIDs processed R:1 N:0 Stub:1 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 1
  Changed LSAs. Recorded is LS ID and LS type:
  192.168.2.1(R)
SPF 4 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:2 N:1 Stub:0 SN:3 SA:0 X7:0
  Change record 0x0
  LSIDs changed 4
  192.168.2.5(R) 192.168.2.1(R) 192.8.178.3(N) 192.168.2.5(R)
SPF 5 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:2 N:1 Stub:0 SN:4 SA:0 X7:0
  Change record 0x0
  LSIDs changed 1
  192.168.2.5(R)
SPF 6 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.1(R)
SPF 7 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.5(R)
SPF 8 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.1(R)
SPF 9 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 0
SPF 10 executed 2d05h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 0
SPF 11 executed 02:07:55 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:2 N:1 Stub:0 SN:6 SA:0 X7:0
  Change record SN, SA
  LSIDs changed 0
SPF 12 executed 01:31:54 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs changed 0
  Area 2: SPF algorithm executed 15 times
  0      0      0      0      0      0      0      0
  LSIDs processed R:4 N:0 Stub:6 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 1
  192.168.2.5(R)
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 0
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 0
SPF 9 executed 04:49:58 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:1 N:0 Stub:0 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 2
  192.168.2.9(R) 192.168.2.1(R)
SPF 10 executed 04:44:27 ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.1(R)
SPF 11 executed 04:44:18 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:2 N:0 Stub:2 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 3
  192.168.2.9(R) 192.168.2.1(R) 192.168.2.9(R)
SPF 12 executed 04:39:13 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:2 N:0 Stub:3 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 1
  192.168.2.9(R)
SPF 13 executed 04:39:04 ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 3
  192.168.2.10(R) 192.168.2.9(R) 192.168.2.10(R)
SPF 14 executed 02:07:59 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs changed 0
SPF 15 executed 01:31:58 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs changed 0
  Area 4: SPF algorithm executed 22 times
SPF 13 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.1(R)
SPF 14 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 3
  192.168.4.2(R) 192.168.2.1(R) 192.168.4.2(R)
SPF 15 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.1(R)
SPF 16 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 1
  192.168.2.1(R)
SPF 17 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 3
SPF 18 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:3 N:0 Stub:4 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 1
  192.168.4.6(R)
SPF 19 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs processed R:3 N:0 Stub:5 SN:0 SA:0 X7:0
  Change record 0x0
  LSIDs changed 1
  192.168.4.6(R)
SPF 20 executed 2d03h ago, SPF type Full
  0      0      0      0      0      0      0      0
  Change record 0x0
  LSIDs changed 3
  192.168.2.5(R) 192.168.4.6(R) 192.168.2.5(R)
SPF 21 executed 02:08:04 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs changed 0
SPF 22 executed 01:32:02 ago, SPF type Full
  0      0      0      0      0      0      0      0
  LSIDs changed 0
6500(ABR1)#
Thanks for reminding; the show ip ospf statistics detail provides even much better information.
So the age of the routing entries in question match the last SPF executions?
I think SPF runs 11 -  12 in Area 0, 14 - 15 in Area 2 and 21 - 22 in Area 4 are particulary interesting: To my best knowledge such SPF runs indicate that a router lost it's ABR status or just became an ABR (possibly both happend since there were two such occurrences).
[EDIT] :
I believe that the SPF runs are triggerd originally from Area 4.
Have a look at the timestamps:
Area 4:
Area 2:
=> 5 seconds later (initial delay to schedule a SPF by default)
Area 0:
=> again 5 seconds later
The second occurrence shows exactly the same order.
