OSPF STATE?
alsayed
DEAR NETPRO EXPERTS!
What does it maean each one of these state?
state
Full/-:
Full/Drother:
Attempt/Drother:
Attempt/drother:
Full/Drother:
Full/BDR:
Many Thannks
ALI
3 Accepted Solutions
paolo bevilacqua
that and more explained in the following document:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094056.shtml
Hope this helps, please rate any useful posts!
ankbhasi
Hi Ali,
In addition you can also keep this lnk handy for OSPF. It's a very good OSPF design guide
http://www.cisco.com/warp/public/104/1.html
Ankur
Friend
1. Full/-: Established adjacency with the neighbor. Mostly would be a case in P2P circuits
2. Full/Drother: Established adjacency with the neighbor which is not DR or BDR. Will be seen in Multiaccess network like ethernet
3. Attempt/Drother: Trying to establish adjacency in Multiaccess network particularly MBMA (trying to find the DR0
4. Attempt/drother: Same as above
5. Full/Drother: Same as in point 2
6. Full/BDR: Established adjacency with the neighbor which is the BDR for the multiaccess segment.
HTH, rate if it does
Narayan
9 Replies 9
paolo bevilacqua
10XS p.bevilacqua !
Friend
Narayan
hi Narayan;10xs a lot for ur reply
ankbhasi
Hi Ali,
Ankur
Ankur MY Freind;how r u hope u doing well.
regards
Ali
Hey ankur,
Nice to see you back.
Congratulations on becoming a father!!!!!!
Narayan
Hey Narayan/Ali,
Thanks for you warm welcome and wishes.
Ankur
yes ankur,
after long time... its really good to see you again in forum...
regards
Devang
