OSPF with stackwise-virtual platform (C9500)
GVD
hi all,
Looking at OSPF as a IGP protocol on a campus/enterprise network, should it be a given that you use a L3 core, instead of a core setup with stackwise-virtual? This will give you the opportunity to make each core DR/BDR. If you would run OSPF one a core which is a stackwise-virtual setup, some random other router/L3 device would become BDR, don't know if that is something you want to have?
balaji.bandi
Why not we consider here point to point link here for OSPF. is this works ?
BB
balaji.bandi
BB
(Light bulb moment)
you are absolutely right, I forgot about the fact that point-to-point does not require BDR!
that would work indeed.
