Ospf
Adam373
Hi i got some misunderstanding about If a network (BMA) contains 5 routers and of course this network has DR/BDR and new router (A) comes in In this case if router A wants to be neighbor with other routers after he is gonna send hello message on 224.0.0.5 now router A in Init stat after the other router respond back its now in 2 way stat my question now I got question 1-does router A stop at 2 way stat after receiving the hello massage from other routers Which tells Router A there is a DR/BDR in this network so DR forward all Others five routers LSDB to router A or router Moves from 2 way stat to exstart to exchange to full
Joseph W. Doherty
Router A should move to "2WAY/DROTHER" status, same as the other 3 routers that are neither the DR or BDR.
Richard Burts
I am somewhat puzzled by the phrasing of the question in the original post. But I agree with Joseph that the behavior is that the new router in the network segment does go through the data base exchange with the DR and the BDR to achieve full adjacency and does not do any data base exchange with the other router routers in the network segment.
Rick
Hi Adam373 ,
In Ospf network type  BMA or NBMA , where DR & BDR are elected . In such network types only the DR - BDR adjacencies &
DR,BDR - DRO adjacencies are " FULL "  , while DRO - DRO adjacencies will be 2WAY/DRO , So the new router that you'll introduce in your network will form Full adjacencies with the DR & BDR , while it will be in 2way/dro with  dro's in the network .
Spooster IT Services Team
Hello
Rtrs that are not DR/BDRs do not become fully adjecent , they will stop at the 2way state as stated by @Joseph W. Doherty , which is a normal process, it shows that these DRothers have bidirectional connectivity with each other, however they will exchange DD packets with the DR so to syc the LSDB.
Kind Regards
Paul
