OTV Join-Interface: loopback or port-channel
cedar_lee
(Moved this post from Data Center community to Network Infrastructure community as no reply from DC community after a week.)
Hello, OTV expert,
Not sure which is better for OTV Join-Interface, loopback or Port-Channel.
Would like to hear your thoughts please.
Cedar
Aries Fernandes
Hi Cedar,
Kindly note that if you are using ASR1000's as your edge-device, they do not allow you to configure loopback interface as your join-interface. You can use port-channel as the join-interface.
I am not much aware in case of nexus. I will get back to you on the same.
Aries
Thanks Aries. Look forward to your investigation.
