output anormal OSPF
ziad-chair
je trouve cette output anormal, que pensez vous SVP de l'état ospf dasn ce cas :
O E1 10.232.51.3/32 [110/53] via 10.4.151.2, 12:16:54, Port-channel20.1017
[110/53] via 10.4.151.2, 12:16:48, Port-channel20.1017
[110/1] via 10.4.151.2, 12:16:54, Port-channel20.1017
Merci d'avance
show ip route | include , 00:00 <<- share this please
MHM
voilà :
sh ip route | i , 00:0
[110/1] via 10.4.151.2, 00:07:30, Port-channel20.1017
Merci
Friend
This meaning there is loop in this route.
The prefix add and then remove, can I see the topology.
Did you use any redistribute between two IGP protocols or between two ospf processes?
Do you use any tunnel?
MHM
thank you so much brother,
"This meaning there is loop in this route.
The prefix add and then remove"
this is what I think too, it's not for me to troubleshoot further,
