Output drops even low input rate
Rojer-bkk
Hi Expert,
I found increasing of total output drops and output queue drops even input rate was low and no qos apply on this interface. I plan to increase hold queue out for output queue. I'm unsure it would help. Appreciated all feedback. Thank you.
Router 1941, 15.0(1)M4
Serial0/0/0 is up, line protocol is up
  Hardware is WIC MBRD Serial
Internet address is 10.182.6.30/30
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 2/255, rxload 1/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 05:28:09
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 815
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/815 (size/max total/threshold/drops)
     Conversations  0/242/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
  30 second input rate 8000 bits/sec, 11 packets/sec
  30 second output rate 17000 bits/sec, 10 packets/sec
     204215 packets input, 36837512 bytes, 0 no buffer
     Received 1969 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     163256 packets output, 90521035 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Although your 30 second transmission rate is low at the time you captured these stats, the fact you had both 242 concurrent flows queued and that you had 815 drops implied sometime during the last 5:28 hours you had congestion.
For a T1, the default WFQ that's running on the interface is difficult to improve on without additional analysis.
Unless you do perform additional analysis, just increasing queue depth might be counter productive.
Joseph W. Doherty
Disclaimer
Posting
