Output queue errors on cisco 2811 ATM1/0 interfaces
nandushankar
Community Member
We are facing output queue problems on our ATM interfaces. A lot of output queue errors are been shown as below. Need help in solving this issue.
Cisco 2811 -> ATM Link -> <-ATM Link <- Cisco 3945 Routers.
Cisco 2811 Version is 124-15.T9.bin
Cisco 3945 Version is SPA.150-1.M1.bin
Cisco 2811 Output Errors
sh int atm1/0 | incl errors|Input
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 11348
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Cisco 3945 Output Errors
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 313
Nandu
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Your "errors" are the output drops?
What their percentage relative to number of packets offered?  (I.e. what's a lot?)
If the issue is output drops due to congestion, if transient congestion, they might be reduced by allocating larger output queues.
Hi Nandu
Can you copy paste the following outputs?
Show int | inc xload
Show run | inc (affected interfaces, you can delete the ip addresses)
Show policy map interface (affected interfaces
Show int sum
Show int stat
Show controllers E1 0/0/0 or whatever controller you have
Nate
Giuseppe Larosa
Hello Nandu,
but what are the interface counters ?
You should always compare the errors to the total number of packets sent out the interface in order to understand if the issue is real or not.
From time to time the queue can fill with bursts of traffic so some drops are natural as the ATM interface is slower then the internal LAN interface.
if you have 11348 drops over several tens of  millions of sent packets you can live with this.
if the ratio output drops / packet sent is 10% this is not acceptable and should be investigated further.
By the way, have you configured any QoS feature on these devices like shaping and/or queueing on the ATM interfaces?
By using QoS you can provide better treatment to packets belonging to important applications for your business
Hope to help
Giuseppe
