output service-policy is not supported on asr1004 port-channel interface
Hello colleagues,
I'm trying output service policy on port-channel subinterface
policy-map CIR-5MB
class class-default
    police cir 5000000
     exceed-action transmit
     violate-action drop
router(config)#interface port-channel2.125
router(config-subif)#service-policy input CIR-5MB
router(config-subif)#service-policy output CIR-5MB
service-policy output CIR-5MB not supported on this target
So I can't to add output service policy and it seems like input service-policy doesn't work:
router#show policy-map interface
Port-channel2.125
  Service-policy input: CIR-5MB
    Service policy CIR-5MB is in suspended mode
So the question is how it's possible to police traffic on port-channel subinterfaces?
5 Replies 5
software asr1000rp2-advipservicesk9.02.06.02.122-33.XNF2
xabrouck
It's not supported yet but it's planned.  Please contact your account team and
ask them to contact the ASR1k product managers.  They will then know you need it and can prioritize better upcoming features.
Xavier
Rudy GAVRON
Hello
I found the same problem with ASR1002, policy-map are always in "suspended" state, so impossible to shape or police traffic.
Is there any IOS new version (currently running old 02.04.02.122-33.XND2) solving this issue ?
Rudy
gheorghe.mihai
To activate the policy-map install the version
03.07.01.S.152-4.S
type this command:
port-channel load-balancing vlan-manual
then it should work.
Here is the doc:
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-eth-int.html
Thanks for the command and link to the relevant document.
Is applying the global command or interface command disruptive to the port channels currently configured and in use on the switch?
Thanks in advance for your response.
