Packet loop during NAT
HQuest
I have a router running IOS 15 on the public Internet which I want to remotely manage using a point to point IPSec tunnel. This tunnel was created just fine, I can log on to the router, I can reach the devices behind this router, any access to behind this router works just fine. I can't, however, go back out on the public Internet while connected via this IPSec tunnel. My NAT configuration attempts so far got me a little frustrated, with three crashinfo files created recently...
The Internet facing interface is set as ip unnumbered, with the valid, public IP address on a VLAN interface. The VLAN is part of a ZBW zone labeled LAN. The Internet interface is on the WAN zone. My IPSec tunnel gives me a 192.168.1.x/24 IP address on a Virtual-Access interface, configured on a VPN zone. As far as I can tell, there are no blocks caused by the ZBW. All these interfaces have an ip nat enable on them.
The NAT is pretty straightforward: one NAT pool with a single, valid IP address, and one overload entry for the tunnel IP range list to the NAT pool. I can see nat translations on the NVI output, but the access don't really get out - or back to the virtual interface. According to the router, packets are looped.
gateway#sh int virtual-access 4
Virtual-Access4 is up, line protocol is up
Hardware is Virtual Access interface
Description: ** IPSec VPN **
Interface is unnumbered. Using address of Loopback1 (192.168.1.1)
MTU 17878 bytes, BW 100 Kbit/sec, DLY 50000 usec,
Encapsulation TUNNEL
Tunnel vaccess, cloned from Virtual-Template1
Vaccess status 0x4, loopback not set
Keepalive not set
Tunnel linestate evaluation up
Tunnel source 200.200.200.201, destination 199.199.199.199
Tunnel protocol/transport IPSEC/IP
Tunnel TTL 255
Tunnel transport MTU 1430 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Tunnel protection via IPSec (profile "vpn-ipsec-profile")
Last input 00:00:03, output never, output hang never
Last clearing of "show interface" counters 00:00:27
Queueing strategy: fifo
Output queue: 0/0 (size/max)
60 packets input, 3649 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
gateway#show policy-map type inspect zone-pair VPN-WAN sessions detail-debug
policy exists on zp VPN-WAN
Zone-pair: VPN-WAN
Service-policy inspect : VPN-WAN-POLICY
Class-map: allow-vpn-wan (match-all)
Match: access-group name allow-vpn-wan_acl
Inspect
Number of Established Sessions = 6
Session 8B53B520 (192.168.1.241:56194)=>(8.8.4.4:53) dns:udp SIS_OPEN
Created 00:00:04, Last heard 00:00:03
Bytes sent (initiator:responder) [492:0]
Initiator->Responder Window size 0 Scale factor 0
Responder->Initiator Window size 0 Scale factor 0
Session 8B53FEA0 (192.168.1.241:61480)=>(8.8.4.4:53) dns:udp SIS_OPEN
Created 00:00:03, Last heard 00:00:02
Bytes sent (initiator:responder) [310:0]
Session 8B540920 (192.168.1.241:51652)=>(8.8.4.4:53) dns:udp SIS_OPEN
Created 00:00:02, Last heard 00:00:01
Bytes sent (initiator:responder) [382:0]
Session 8B544120 (192.168.1.241:64433)=>(8.8.4.4:53) dns:udp SIS_OPEN
Created 00:00:01, Last heard 00:00:00
Bytes sent (initiator:responder) [208:0]
Session 8B541020 (192.168.1.241:56194)=>(8.8.8.8:53) dns:udp SIS_OPEN
Session 8B53AE20 (192.168.1.241:61480)=>(8.8.8.8:53) dns:udp SIS_OPEN
Created 00:00:00, Last heard 00:00:00
Bytes sent (initiator:responder) [155:0]
Class-map: INTERNAL_DOMAIN_FILTER (match-any)
Match: protocol msnmsgr
0 packets, 0 bytes
30 second rate 0 bps
Match: protocol ymsgr
0 packets, 0 bytes
Inspect
Class-map: class-default (match-any)
Match: any
Drop
0 packets, 0 bytes
gateway#show ip nat nvi translations
Pro Source global Source local Destin local Destin global
udp 200.200.200.200:51652 192.168.1.241:51652 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:53474 192.168.1.241:53474 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:53474 192.168.1.241:53474 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:55029 192.168.1.241:55029 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:55029 192.168.1.241:55029 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:55503 192.168.1.241:55503 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:55503 192.168.1.241:55503 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:56194 192.168.1.241:56194 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:56194 192.168.1.241:56194 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:59885 192.168.1.241:59885 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:59885 192.168.1.241:59885 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:61480 192.168.1.241:61480 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:61480 192.168.1.241:61480 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:64433 192.168.1.241:64433 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:64433 192.168.1.241:64433 8.8.8.8:53 8.8.8.8:53
udp 200.200.200.200:64603 192.168.1.241:64603 8.8.4.4:53 8.8.4.4:53
udp 200.200.200.200:64603 192.168.1.241:64603 8.8.8.8:53 8.8.8.8:53
Below are some of the output from the router console:
Mar 4 15:15:44: %CRYPTO-6-EZVPN_CONNECTION_UP: (Server) Mode=CLIENT_OR_NEM_PLUS Client_type=CISCO_SW_VPN_CLIENT User=XXX Group=XXX Client_public_addr=199.199.199.199 Server_public_addr=200.200.200.201 Assigned_client_addr=192.168.1.241
Mar 4 15:15:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access4, changed state to up
Mar 4 15:15:45: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=8.8.4.4, dst=192.168.1.241, hl=20, tl=103, prot=17, sport=53, dport=51652
in=Virtual-Access4, nexthop=192.168.1.241, out=Virtual-Access4
options=none -Process= "IP Input", ipl= 0, pid= 144
-Traceback= 814D03DCz 81CA21B8z 81C7921Cz 81C79360z 81C79904z 81C7A260z 81C73514z 81C73934z 81C7A7D8z 81C72AE8z 81C72D68z 81C72FD4z 81C732F8z 8068B538z 80672834z
Configuration snippet following. Suggestions?
interface Loopback1
zone-member security VPN
interface Virtual-Template1 type tunnel
ip unnumbered Loopback1
ip nat enable
tunnel mode ipsec ipv4
tunnel protection ipsec profile vpn-ipsec-profile
interface GigabitEthernet 0/0
ip unnumbered Vlan999
ip nat enable
zone-member security WAN
interface Vlan999
ip address 200.200.200.201 255.255.255.240
ip nat enable
zone-member security LAN
object-group network vpn_remote_subnets
192.168.1.0 255.255.255.0
ip access-list extended nat-list
permit ip object-group vpn_remote_subnets any
deny ip any any
ip nat pool wan-ip-pool 200.200.200.200 200.200.200.200 netmask 255.255.255.240 ! single address for the NAT, netmask of the WAN interface
ip nat source list nat-list pool wan-ip-pool overload
6 Replies 6
from the output:
it looks like the destination is the same as the next hop, which is probably what causes the loop. The source is the Google DNS server, which makes me wonder if you can access a public website through its IP address ?
Can you post the full config of your router ?
Uhm, not really able to get the config in full. Any partition you are looking in particular?
Now, I have to mention that this used to work until the valid IP address was moved off the physical Gi0/0 interface to the VLAN interface. The NAT address was then tied to this interface as of
ip nat source list nat-list interface Gi0/0 overload
, however now that it should go out using its own static, public address, doesn't work anymore. But that made me think, "what if...", and I did change the NAT to
ip nat source list nat-list interface Vlan999 overload
and guess what, it "works". Leaves out to the wild with the router VLAN interface IP address and not with my desired IP address, but works.
So maybe my follow up question to my own questions are, can't NAT be assigned to an unnumbered interface?
without seeing the full configs of both sides of the SVTI tunnel, it remains guesswork why the NAT doesn't work on the unnumbered interface. Do you use static routing ?
The tunnel is a basic EZVPN, with a pre-shared key on the router side, and a road warrior client on the other side - that can be a Cisco VPN client, an iOS device...
crypto isakmp policy 1
encr aes 256
hash sha512
authentication pre-share
group 14
crypto isakmp keepalive 90
crypto isakmp client configuration address-pool local vpn-ip-pool
crypto isakmp client configuration group XXX
key 6 ...
dns 200.200.200.201
domain XXX
pool vpn-ip-pool
include-local-lan
pfs
max-users 5
netmask 255.255.255.0
crypto isakmp profile vpn-isakmp-profile
match identity group XXX
client authentication list XXX
isakmp authorization list XXX
client configuration address initiate
client configuration address respond
keepalive 90 retry 2
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile vpn-ipsec-profile
set security-association idle-time 900
set transform-set ESP-3DES-SHA
set pfs group1
set isakmp-profile vpn-isakmp-profile
ip local pool vpn-ip-pool 192.168.1.241 192.168.1.245
The only static route is for the upstream provider, internally all routes are provided via OSPF.
Alexandre,
can you try and use 'traditional' NAT, with 'ip nat inside' and 'ip nat outside' commands instead of 'ip nat enable' ? I wonder if the 'ip unnumbered' problem is related to the NAT Virtual Interface...
Well, yes, it works with traditional NAT, including the manual IP address assignment. Guess I did not researched long enough, but it explains why it worked on other scenarios (with VRFs) but not on this scenario (without VRFs):
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/26704-nat-faq-00.html
Q. What is NAT NVI?
A. NVI stands for NAT Virtual Interface. It allows NAT to translate between two different VRFs. This solution should be used in lieu of Network Address Translation on a Stick.
Q. Should NAT NVI be used when NATting between an interface in global and an interface in a VRF?
A. Cisco recommends that you use legacy NAT for VRF to global NAT (ip nat inside/out) and between interfaces in the same VRF. NVI is used for NAT between different VRFs.
Anyway, back to the drawing board. Appreciated your time lending a fresh set of eyes.
