: %PARSE_RC-4-PRC_NON_COMPLIANCE: `no service udp-small-servers'
Hi ,
I am receiving  below logged which were observed during script pushing through  solarwinds.
Aug 14 16:20:00.669  UAE: %PARSE_RC-4-PRC_NON_COMPLIANCE: `no service udp-small-servers',   -Traceback= 0x419AB2ACz 0x419ABF78z 0x419AF324z 0x419D4EB0z 0x43C30150z  0x43C2104Cz 0x432120E4z 0x432120C8z
Aug 14 16:20:01.041  UAE: %PARSE_RC-4-PRC_NON_COMPLIANCE: `no service tcp-small-servers',   -Traceback= 0x419AB2ACz 0x419ABF78z 0x419AF324z 0x419D4EB0z 0x43C30150z  0x43C2104Cz 0x432120E4z 0x432120C8z
Aug 14 16:20:01.357  UAE: %PARSE_RC-4-PRC_NON_COMPLIANCE: `no service finger',  -Traceback=  0x419AB2ACz 0x419ABF78z 0x419AF324z 0x419D4EB0z 0x43C30150z 0x43C2104Cz  0x432120E4z 0x432120C8z
Aug 14 16:20:01.669  UAE: %PARSE_RC-4-PRC_NON_COMPLIANCE: `no service pad',  -Traceback= 0x419AB2ACz  0x419ABF78z 0x419AF324z 0x419D4EB0z 0x43C30150z 0x43C2104Cz 0x432120E4z  0x432120C8z
I would appreciate if someone share experince on above logs,
I am having following image running on the router,
Cisco  IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T5,  RELEASE SOFTWARE (fc3)
Technical  Support: http://www.cisco.com/techsupport
Copyright  (c) 1986-2011 by Cisco Systems, Inc.
Compiled  Fri 04-Mar-11 03:52 by prod_rel_team
ROM:  System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE  (fc1)
FUJ-2811-01  uptime is 29 weeks, 5 hours, 25 minutes
System  returned to ROM by power-on
System  restarted at 08:49:36 UAE Mon Jan 28 2013
System  image file is  "flash:c2800nm-advipservicesk9-mz.124-24.T5.bin"
Cisco  2811 (revision 53.51) with 247808K/14336K bytes of memory.
2  FastEthernet interfaces
1  Virtual Private Network (VPN) Module
DRAM  configuration is 64 bits wide with parity enabled.
239K  bytes of non-volatile configuration memory.
62720K  bytes of ATA CompactFlash (Read/Write)
Configuration  register is 0x2102
Also I wanted to add when initaiting job from solarwinds , on ther server i was getting "Authorization failed" while on the router i was getting above mentioned traceback,
