06-21-2008 01:58 AM - edited 03-03-2019 10:26 PM
I have switch 2560 and i forgot the password so .
Is the method of password reset make switch default or just password???
06-21-2008 02:15 AM
Hi!
Follow the procedure mentioned in the link below to recover the password.
http://www.cisco.com/warp/public/474/pswdrec_2500.html
In case you donot require the previous configuration of the device, you can skip steps 10 and 11.
Hope this helps.
niranjan.
(pls rate if this helps)
Log in to Community
