PBR and Virtual Interfaces
chrisayres
Level 4
Level 4
I am dynamically applying PBR to a virtual-access int via AV Pairs.
However not all traffic that should be policy routed is being, some is rejected and normal routed, If I remove CEF from the virtual-template nothing is PBR'd so it is definitely doing some PBR routing but not catching every packet. see below config's, debug and ping results.
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 17:00 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
route-map mymap permit 10
 match ip address mymapacl
 set ip next-hop 1.1.1.1
ip access-list standard mymapacl
 permit any
interface Virtual-Template1
 ip unnumbered Loopback100
 no peer default ip address
 ppp authentication chap
interface Virtual-Access3
 ip policy route-map mymap
453540: May 29 08:44:16: IP: route map mymap, item 10, permit
453541: May 29 08:44:16: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, policy rejected -- normal forwarding
453542: May 29 08:44:17: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, FIB policy match
453543: May 29 08:44:17: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, PBR Counted
453544: May 29 08:44:17: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, g=1.1.1.1, len 60, FIB policy routed
453545: May 29 08:44:17: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, policy match
453546: May 29 08:44:17: IP: route map mymap, item 10, permit
453547: May 29 08:44:17: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, policy rejected -- normal forwarding
453548: May 29 08:44:18: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, FIB policy match
453549: May 29 08:44:18: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, PBR Counted
453550: May 29 08:44:18: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, g=1.1.1.1, len 60, FIB policy routed
453551: May 29 08:44:18: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, policy match
453552: May 29 08:44:18: IP: route map mymap, item 10, permit
453553: May 29 08:44:18: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, policy rejected -- normal forwarding
453554: May 29 08:44:19: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, FIB policy match
453555: May 29 08:44:19: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, PBR Counted
453556: May 29 08:44:19: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, g=1.1.1.1, len 60, FIB policy routed
453557: May 29 08:44:19: IP: s=10.10.20.75 (Virtual-Access3), d=10.248.19.153, len 60, policy match
453558: May 29 08:44:19: IP: route map mymap, item 10, permit
Request timed out.
Reply from 10.10.20.75: bytes=32 time=54ms TTL=118
Reply from 10.10.20.75: bytes=32 time=59ms TTL=118
Request timed out.
Request timed out.
Reply from 10.10.20.75: bytes=32 time=57ms TTL=118
Reply from 10.10.20.75: bytes=32 time=60ms TTL=118
Reply from 10.10.20.75: bytes=32 time=61ms TTL=118
Request timed out.
Reply from 10.10.20.75: bytes=32 time=58ms TTL=118
Request timed out.
Request timed out.
Request timed out.
Reply from 10.10.20.75: bytes=32 time=56ms TTL=118
Peter Paluch
Hi Chris,
Unfortunately, this looks like a bug. The configuration does not seem to be specific in any way. Just curious, do you think you can afford to put the PBR route-map on the Virtual-Template interface statically and for the time being, remove the AV pairs from your RADIUS/TACACS+? I am trying to find out if the problem is generally related to the way the Virtual-Template is instantiated into Virtual-Access interfaces and their configuration cloned, or whether there is some specific regression in the dynamic application of the route-map via the AV pairs.
In any case, do you have an option of raising this issue with TAC?
Best regards,
Peter
Peter Paluch
Hi Chris,
Best regards,
Peter
Hi, yep I suspected as much. I moved the policy onto the virtual-template and got the same results.
I will get TAC onto it
