10-22-2019 10:28 AM
I have a C6816-X-LE running the latest IOS 15.5(1)SY4. Here is my PBR config
interface te1/1 ip policy route-map PROV_USSATS ! ip access-list extended PROV_USSATS deny ip any 172.16.0.0 0.0.255.255 deny ip any 172.19.0.0 0.0.255.255 deny ip any 10.92.0.0 0.0.255.255 deny ip any 10.135.0.0 0.0.255.255 permit ip host 172.22.136.226 any permit ip host 172.22.154.90 any permit ip host 172.22.128.178 any ! route-map PROV_USSATS permit 10 match ip address PROV_USSATS set ip next-hop verify-availability 10.82.6.26 1 track 1
The track is up
#sho track 1
Track 1
IP route 198.18.4.212 255.255.255.255 reachability
Reachability is Up (BGP)
2 changes, last change 00:36:08
VPN Routing/Forwarding table "SAT"
First-hop interface is TenGigabitEthernet1/7
Tracked by:
Route Map 0However, if I remove the "verify-availability" and the "track" (so it will be like "set ip next-hop x.x.x.x), it works. What did I do wrong?
The next-hop is directly connected. There is the ARP entry for it
#sh ip arp vrf SAT 10.82.6.26 Protocol Address Age (min) Hardware Addr Type Interface Internet 10.82.6.26 52 a46c.2acf.4663 ARPA TenGigabitEthernet1/7
Please note that all these are in one VRF. The PBR is not for the cross-VRF thing. It is for changing the next-hop within the same VRF.
Difan
10-23-2019 08:56 AM
Nope
track 2 ip sla 2 ! ip sla 2 icmp-echo 10.82.6.26 source-interface TenGigabitEthernet1/7 vrf SAT threshold 500 timeout 1000 frequency 3 ! ip sla schedule 2 life forever start-time now ! route-map PROV_USSATS permit 10
set ip next-hop verify-availability 10.82.6.26 1 track 2
wsw01-07r1#show ip sla statistics IPSLAs Latest Operation Statistics IPSLA operation id: 2 Latest RTT: 1 milliseconds Latest operation start time: 09:54:40 MDT Wed Oct 23 2019 Latest operation return code: OK Number of successes: 57 Number of failures: 0 Operation time to live: Forever ! wsw01-07r1#show track 2 Track 2 IP SLA 2 state State is Up 1 change, last change 00:02:45 Latest operation return code: OK Latest RTT (millisecs) 1 Tracked by: Route Map 0 !
wsw01-07r1#debug ip policy Policy routing debugging is on wsw01-07r1#ter moni Oct 23 09:53:51.756 MDT: IP: s=172.22.128.178 (TenGigabitEthernet1/1), d=4.2.2.1, len 64, policy match Oct 23 09:53:51.756 MDT: IP: route map PROV_USSATS, item 10, permit Oct 23 09:53:51.756 MDT: IP: s=172.22.128.178 (TenGigabitEthernet1/1), d=4.2.2.1 (TenGigabitEthernet1/7), len 64, policy routed Oct 23 09:53:51.756 MDT: IP: TenGigabitEthernet1/1 to TenGigabitEthernet1/7 10.82.6.26
Same symptom. Debug says it is policy-routed, however, traceroute says otherwise...
10-23-2019 10:29 AM
Hello
curious- you are trace route within vrf and sourced from the pbr interface?
Do you get the same trace route result from a host behind the pbr interface
Can you post results of trace-route with-without track please and also
Show Ip cef exact-route (sip) (dip)
10-23-2019 11:11 AM
Hi Paul,
I do traceroute from a linux host that has the IP in the matched ACL. This is when it is working (without the track). The highlighted IP is the next-hop IP in the PBR config.
Even without track, with the PBR working, the "show ip cef exact-route" still reports that it is going by the routing table
wsw01-07r1#sh ip cef vrf SAT exact-route 172.22.128.178 4.2.2.1 172.22.128.178 -> 4.2.2.1 =>IP adj out of Vlan986, addr 192.168.250.70
wsw01-07r1#sh ip route vrf SAT 0.0.0.0
Routing Table: SAT
Routing entry for 0.0.0.0/0, supernet
Known via "bgp 64610", distance 20, metric 0, candidate default path
Tag 64700, type external
Last update from 192.168.250.70 1d01h ago
Routing Descriptor Blocks:
* 192.168.250.70, from 192.168.250.70, 1d01h ago
Route metric is 0, traffic share count is 1
AS Hops 4
Route tag 64700
MPLS label: none
10-23-2019 11:19 AM
I did (another) pretty extensive search, and it actually looks like the tracking option in conjunction with the verify-availability is not supported on any of the Catalysts...
The document below seems to confirm this (scroll down to the bottom)...
-->2. Tracking options are not available for Cisco Catalyst Switches. However, there's an advanced workaround available to achieve the same behavior.
10-23-2019 11:23 AM
Thanks Georg. That's what suspected too. I will try to use EEM to accomplish it. Thank you for your effort into this.
