ā10-04-2022 08:17 AM
I have wireless Vlan subnet which is shared on Three Sites, here WLC is located in Data Center and we have SCCM DP server at Site 2 and Site 3 Now for Site 2 & 3 Traffic for Wireless user to SCCM DP Server is first going out to WAN to DC then its coming Back to Site. While Both Wireless user and SCCM DP server are locally to Site.
we are using Cisco 6840 as L3 Switch. so my question is can we do PBR on Cisco 6840 for routing traffic locally to SCCM DP server.
ā10-04-2022 08:27 AM
absolutely. Do you need help setting up the configuration? I have a few PBRs at the core level for certain networks. Pencil sketch a diagram of how you want the packets to route. You dont need to visio it unless you have the time.
ā10-04-2022 09:06 AM
Thanks , Can you please share sample configuration. we want to apply it based on destination. so on core switch where we need to apply router Map. can we use Local PBR or we have to apply it on interface going toward router/ or Vlan having destination IP.
ā10-06-2022 08:12 AM
my bad bro. ive been busy on contact center setups. you want a GRE or just interface sample?
ā10-06-2022 08:18 AM
if you want a simple overview check out this guys setup: https://networklessons.com/cisco/ccie-routing-switching/how-to-configure-policy-based-routing
