PBR
Handian
If we have PBR command like below :
set ip next-hop verify-availability A.A.A.A 1 track 1
set ip next-hop verify-availability B.B.B.B 2 track 2
set ip next-hop verify-availability C.C.C.C 3 track 3
The traffic will be re-route to B.B.B.B if track 1 down, am i right?
If track 1 coming up, will the traffic re-route back to A.A.A.A or still use B.B.B.B?
balaji.bandi
as per your theory yes, it fails to B if A not reachable, Once A reachable it should fail back to A - subject to your configuration of IP sla and tracking.
post complete configuration
below example help you :
https://packetpushers.net/using-ip-sla-delay-feature-to-safely-monitor-lossy-links/
BB
balaji.bandi
BB
I just lab-tested your setup in GNS3, if your config looks like below (IP addressing is arbitrary, obviously), it should work as intended.
ip cef
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 ip sla 3 reachability
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.252
interface GigabitEthernet0/1
ip address 2.2.2.1 255.255.255.252
interface GigabitEthernet0/2
ip address 3.3.3.1 255.255.255.252
interface GigabitEthernet0/3
ip policy route-map PBR
ip sla 1
icmp-echo 1.1.1.2 source-interface GigabitEthernet0/0
threshold 300
timeout 500
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 2.2.2.2 source-interface GigabitEthernet0/1
threshold 300
timeout 500
frequency 5
ip sla schedule 2 life forever start-time now
ip sla 3
icmp-echo 3.3.3.2 source-interface GigabitEthernet0/2
threshold 300
timeout 500
frequency 5
ip sla schedule 3 life forever start-time now
route-map PBR permit 10
match ip address 101
set ip next-hop verify-availability 1.1.1.2 10 track 1
set ip next-hop verify-availability 2.2.2.2 20 track 2
set ip next-hop verify-availability 3.3.3.2 30 track 3
access-list 101 permit ip 192.168.1.0 0.0.0.255 host 8.8.8.8
