Performance Management ?
sdawson35
Apologies as I am not sure this is the correct place to post this question,
We have 2 office locations , One has two Cat 650x's and the other two Nexus 5k's, each device is connected via a seperate carriers
Site A                                                      Site_B
Switch_1a               carrier_X                        Switch_1b
Switch_2a               carrier_Y                        Switch_2b
No external routers involved as we are using L3 on the switches.
I need to be able to monitor and check bandwidth between the devices , however cannot find any tools for doing this (IPSLA would I think be ideal but no support for it on the 5k's)
Does anybody have any ideas ?, I should add that I would need to be able to either select source routing via ip address or interface so as to test each carrier similtaneously and compare results.
Scott.
Hello
I think NetFlow is applicable to your requirements- please review the link belwo
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/prod_white_paper0900aecd80406232.html
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
