465
PFR Inbound/Outbound optimization
Hi.
I hope you are all doing well, and I'm sorry for posting such a long OT.
Straight to the issue, we have one 7609S which its IOS is 15.1(3)S. I should note that this an ISP environment and this router has 15 private IX peers, and 4 Exit links. The IX paths are not being advertised to eBGP exit peers.
I've configured the router being MC and BR the same time, 1 Internal interface, and 5 External interface.
I should note that we have categorized our BGP peers in 3 different template peer-policy.
  1. Also each eBGP exit peer is assigned an outbound route-map which denies IX paths to be advertised to them and also doing manaul prepending. Is this conflicting with what PFR does in prepending to AS-PATH?
  2. The issue is that, I see our routes are dampened a lot in the world of BGP, and I see no prepending to my AS-PATH when checking on route-views in different time.
  3. Why no probe is learned for the traffic over Tunnels?
  4. What is your opinion regarding the PFR parameters for an ISP?
Below you will find configurations and shows.
And I'm again sorry for such long post.
ip route 0.0.0.0 0.0.0.0 192.168.64.1
ip route 0.0.0.0 0.0.0.0 172.16.101.2
ip route 0.0.0.0 0.0.0.0 172.16.105.2
ip route 0.0.0.0 0.0.0.0 172.16.13.1
router bgp ******
template peer-policy CUST_BGP
  route-map BGP_CUST_NO-OUT out
  default-originate
  soft-reconfiguration inbound
  send-community both
exit-peer-policy
template peer-policy BW_UPLINKS
  prefix-list ISP_IX-in in
  next-hop-self all
  send-community both
exit-peer-policy
template peer-policy IX
  route-map IX_BGP-OUT out
  next-hop-self all
  send-community both
neighbor 172.16.101.2 remote-as ****
neighbor 172.16.101.2 route-map EXIT1-OUT out
neighbor 172.16.101.2 inherit peer-policy BW_UPLINKS
route-map EXIT1-OUT deny 1
description not advertising IX paths (AS) to PARDIS
match as-path 1
route-map EXIT1-OUT permit 10
description Advertising all other prefixes
set as-path prepend *****
!!!! OTHER eBGP exit peers have similar configuration!!!!
HT-CoreRT#s pfr mas
OER state: ENABLED and ACTIVE
  Conn Status: SUCCESS, PORT: 3949
  Version: 3.1
  Number of Border routers: 1
  Number of Exits: 4
  Number of monitored prefixes: 779 (max 5000)
  Max prefixes: total 5000 learn 2500
  Prefix count: total 779, learn 779, cfg 0
  PBR Requirements met
  Nbar Status: Inactive
Border           Status   UP/DOWN             AuthFail  Version  DOWN Reason
172.31.255.14    ACTIVE   UP       04:29:03          0  3.1
OER master in special monitor mode
Global Settings:
  max-range-utilization percent 60 recv 30
  rsvp post-dial-delay 0 signaling-retries 1
  mode route metric bgp local-pref 5000
  mode route metric static tag 5000
  trace probe delay 1000
  no logging
  exit holddown time 60 secs, time remaining 0
Default Policy Settings:
  backoff 150 150 150
  delay relative 50
  holddown 200
  periodic 150
  probe frequency 56
  number of jitter probe packets 100
  mode route control
  mode monitor both
  mode select-exit good
  loss relative 10
  jitter threshold 20
  mos threshold 3.60 percent 30
  unreachable relative 50
  resolve utilization priority 1 variance 2
  resolve range priority 2 variance 0
Learn Settings:
  current state : SLEEP
  time remaining in current state : 148 seconds
  throughput
  no delay
  inside bgp
  monitor-period 5
  periodic-interval 5
  aggregation-type prefix-length 24
  prefixes 400 appls 400
  expire after time 30
HT-CoreRT#sh pfr bor active-probes
echo     5.134.193.10        N ********    PO8/1/0               6       6
echo     2.125.42.232        N *******    PO8/1/0               6       5
echo     109.162.130.162     N ******    Gi8/0/1               6       5
echo     109.162.130.114     N ********    Gi8/0/1               6       6
HT-CoreRT#show pfr mas traffic-class inside
x.x.80.0/22            N    N    N           N           N N
               #          INPOLICY       38     172.31.255.14 Tu105           BGP
               U        U        0        0        0        0    10483     3470
               U        U        0        0        N        N        N        N
x.x.84.0/22            N    N    N           N           N N
               #         HOLDDOWN*      166     172.31.255.14 PO8/1/0         BGP
               U        U        0        0        0        0     4767    19494
               U        U        0        0        N        N        N        N
x.x.88.0/22            N    N    N           N           N N
               #          HOLDDOWN       87     172.31.255.14 PO8/1/0         BGP
               U        U        0        0        0        0    21402    20568
               U        U        0        0        N        N        N        N
x.x.128.0/24           N    N    N           N           N N
               #          DEFAULT*        0     172.31.255.14 Tu101           U
               U        U        0        0        0        0        8       10
               U        U        0        0        N        N        N        N
HT-CoreRT#sh pfr mas traffic-class performance inside
Traffic-class: (inside)
Destination Prefix : x.x.88.0/22          Source Prefix    : N/A
Destination Port   : N/A                     Source Port      : N/A
DSCP               : N                       Protocol         : N/A
Application Name:  : N/A
General:
   Control State                   : Controlled using BGP
   Traffic-class status            : HOLDDOWN
   Current Exit                    : BR 172.31.255.14 interface Gi8/0/1, Tie breaker was Non-OER
   Time on current exit            : 0d 0:0:8
   Time remaining in current state : 162 seconds
   Last uncontrol reason           : Couldn't control
   Time since last uncontrol       : 0d 0:1:24
   Traffic-class type              : Learned
   Improper config                 : None
Last Out of Policy event:
   Reason                          : Range
   Time since Out of Policy event  : 0d 0:1:19
   Link OOP; no prefix performance :
Average Passive Performance Current Exit: (Average for last 5 minutes)
   Unreachable            : 0% -- Threshold: 50%
   Delay                  : 0% -- Threshold: 50%
   Loss                   : 0% -- Threshold: 10%
   Egress BW              : 16197 kbps
   Ingress BW             : 15232 kbps
   Time since last update : 2d 0:37:21
Average Active Performance Current Exit: (Average for last 5 minutes)
This platform does not support "ip flow egress" on interfaces, but "ingress" is configured on all the router's interfaces.
HT-CoreRT#sr | s flow
ip flow-cache timeout active 1
mls netflow cache
mls flow ip interface-destination-source
no mls flow ipv6
ip flow ingress
ip flow-export source Loopback17231255
ip flow-export version 9
ip flow-aggregation cache as
enabled
ip flow-aggregation cache prefix
mask source minimum 24
mask destination minimum 24
enabled
Destination Prefix : x.x.96.0/22          Source Prefix    : N/A
General:
   Control State                   : Not Controlled
   Traffic-class status            : HOLDDOWN*
   Current Exit                    : BR 172.31.255.14 interface Tu105, Tie breaker was Non-OER
   Time on current exit            : 0d 0:0:9
   Time remaining in current state : 90 seconds
   Time since last uncontrol       : 0d 0:1:45
   Reason                          : Range
   Time since Out of Policy event  : 0d 0:1:45
   Egress BW              : 9001 kbps
   Ingress BW             : 25642 kbps
   Time since last update : 2d 0:38:17
Best Regards,
Mohammad Moghaddas
Everyone's tags (5)
Ask the Expert- Webex Hybrid Services Solutions
