PfRv3 Dual DMVPN HuB support
vinod_sharma7
Just wanted to check if we support dual DMVPN HuB topology. We have 1 internet and 1 MPLS connection in primary DC and backup MPLS link in secondary DC. We are looking to use secondary MPLS DC link as a backup. I am attaching the topology for your reference.
Any further question, please let me know, appreciate your support.
vamikhai
Hello.
The network topology does not look supported, as you have backdoor links between the sites.
vamikhai
Hello.
Hello Mikhail,
Thanks.That fixed the problem partially and i am working on the other bits, also wanted to check, if PfR is supported on single underlay (MPLS as transport from same provider) and build dual DMVPN tunnel over MPLS transport. attaching a snapshot for your reference.
