pim multicast - basic config
obi
I'm part of a group of sites that are trying to multicast to each other. I'm showing on the neighbor table and in mroute on one of the routers between locations, but am unable to get my streams to be picked up by others. I *can* see the stream from one of the other sites. While I wait for:
  • working site's television engineer to track down the person that set up their router
and
  • yes/no confirmation that my latest config is working (just heard. it's a no)
I thought I'd post it here. Very last change was to enable bidirectional multicast (which worked for someone in another thread).
Any insights would be tremendously appreciated.
First, a factory reset, followed by
gave myself a login, then pasted the following:
hostname MCST-ONLY-01
ip multicast-routing
ip pim rp-address 199.x.x.x
ip route 0.0.0.0 0.0.0.0 199.x.x.x
ip mroute 0.0.0.0 0.0.0.0 199.x.x.x
ip pim bidir-enable
interface f8
ip address 199.x.x.x 255.255.255.248
ip pim sparse-mode
interface vlan1
ip address 10.10.10.1 255.255.255.0
ip pim sparse-mode
resulting in the following config:
MCST-ONLY-01#show running-conf
Building configuration...
Current configuration : 3966 bytes
! Last configuration change at 20:55:15 UTC Tue Oct 1 2013 by obi
! NVRAM config last updated at 20:55:17 UTC Tue Oct 1 2013 by obi
version 15.1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn FTX163886MG
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
ip pim sparse-mode
duplex auto
speed auto
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip pim sparse-mode
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip pim bidir-enable
ip pim rp-address 199.8.216.31
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
mgcp profile default
line con 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
MCST-ONLY-01#
thanks again.
Vishesh Verma
Multicasting networks have more design issues than configuration problems.
The configuration is fine. But we need to have a clear understanding of what we are trying to achieve and how the traffic will flow fron the source to this router.
My Questions : -
  1. This 199 IP, is it part of your AS ?
  2. Does this peer have pim enabled ?
  3. Do we have pim neighborship to that neighbor (show ip pim neighbor)?
  4. Is it different from (ip route 0.0.0.0 0.0.0.0 199.x.x.x) ?
  5. Where is RP 199.8.216.31 located in the network?
  6. Does this router have receivers for the Group G?(show ip igmp groups)
  7. Do you see (*,G) joins forwarded to pim neighbor upstream?
  8. Does the RP has (S,G) for the group?
  9. Is the RPF correct in the transit path from this router to RP?
  10. Why are you trying to run pim in bidir mode?
  11. Can you post a network diagram ?
  12. Also please post a mtrace 199.8.216.31 and a trace from RP to interface FastEthernet8 IP.
Didn't even consider how confusing trying to mask my addresses would make things.
Short version:
THIS router, the one I'm working on, is 199.8.201.100
next hop is my ISP's router, 199.8.201.97 (which is the default route/mroute)
RP is somewhere at the ISP.
I have access to a web based console where I can enter sh commands.
To my knowledge all peers are PIM-enabled.
if i sh neighbor on my router, i see only .97
working on getting answers to the rest of your q's.
thanks for trying to help with this!
I assume yes.
also assumptive yes
my router shows this as the only neighbor:
Neighbor     Interface      Uptime/Expires    Ver   DR
Address                                             Prio/Mode
199.8.201.97 FastEthernet8  22:53:56/00:01:34 v2    1 / S P G
no, both are 199.8.201.97. the only thing I'm 100% sure about
beyond the next hop. checking with ISP
MCST-ONLY-01#sh ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.0.1.38       Vlan1                    22:41:39  00:02:27  10.10.10.45
239.255.255.250  Vlan1                    22:41:39  00:02:28  10.10.10.4
233.0.87.102     Vlan1                    15:29:26  00:02:28  10.10.10.4
233.6.231.4      Vlan1                    22:41:40  00:02:26  10.10.10.35
233.6.231.3      Vlan1                    22:41:39  00:02:28  10.10.10.20
224.0.1.40       FastEthernet8            22:41:50  00:02:51  199.8.201.100
These have been forwarded to the ISP
no good reason. saw it mentioned in another thread and assumed that since I was getting data in but not sending it out that it would be worth trying. Will switch it off if it's not doing me any good.
streaming source 233.6.231.4 (10.10.10.40)
FE1 on router, vlan1 10.10.10.1
FE8 on router 199.8.201.100
ISP 199.8.201.97
MCST-ONLY-01#mtrace 199.8.216.31
Mtrace from 199.8.216.31 to 199.8.201.100 via RPF
From source (?) to destination (?)
Querying full reverse path...
0  199.8.201.100
-1  199.8.201.100 PIM  [default]
-2  199.8.201.97 None No route
I hope at least some of this is helpful. Thanks again.
0  199.8.201.100
It seems the issue is not on your router but on the ISP router(199.8.201.97) connected to yours.
Possible issues -
  • Incorrect RPF for the RP
  • Pim not enabled on path upstream to RP
Please do a traceroute and ping from your router to 199.8.216.31 and let me know of the output.
How to be sure that issue is with the ISP -
  • traceroute and mtrace should have same results complete path, the hop where you see a deflection could potentially be the INTERESTING-HOP with problem
  • traceroute and mtrace should have same results for complete path the hop where you see a deflection could potentially be the INTERESTING-HOP with problem
  • Note that if the above traces are incomplete as in your example above especially mtrace then it means multicast RPF is broken
  • show ip mroute 233.6.231.4 should have the (*,G) as the receivers joins a group and as soon as the router receives the multicast stream it should have (S,G)
Example -
(1.1.1.1)Source----R1----R2----R3----R4----Receiver
Output of R4 where receiver joins 229.0.0.1 but no source is sending the stream
R4#show ip mroute 229.0.0.1
(*, 229.0.0.1), 00:00:07/00:02:52, RP 2.2.2.2, flags: SJCL
  Incoming interface: FastEthernet0/0, RPF nbr 34.0.0.3
  Outgoing interface list:
    FastEthernet0/1, Forward/Sparse, 00:00:07/00:02:52
Output of R4 where receiver joins 229.0.10.10 and source 1.1.1.1 connected to R1 is sending the multicast stream.
R4#show ip mroute 229.0.10.10
(*, 229.0.10.10), 00:00:11/stopped, RP 2.2.2.2, flags: SJCL
    FastEthernet0/1, Forward/Sparse, 00:00:11/00:02:48
(1.1.1.1, 229.0.10.10), 00:00:09/00:02:58, flags: LJT
    FastEthernet0/1, Forward/Sparse, 00:00:09/00:02:50
Output of mtrace to source from R4
R4#mtrace 1.1.1.1
Mtrace from 1.1.1.1 to 34.0.0.4 via RPF
0  34.0.0.4
-1  34.0.0.4 PIM  [1.1.1.0/24]
-2  34.0.0.3 PIM  [1.1.1.0/24]
-3  23.0.0.2 PIM  [1.1.1.0/24]
-4  12.0.0.1 PIM  [1.1.1.0/24]
-5  1.1.1.1
Output of trace to source from R4
R4#traceroute 1.1.1.1
Tracing the route to 1.1.1.1
  1 34.0.0.3 32 msec 52 msec 32 msec
  2 23.0.0.2 56 msec 64 msec 60 msec
  3 12.0.0.1 96 msec 106 msec 124 msec
If the multicast path is broken in between; you will see the mtrace also broken and hence we can identify the potential hop with the issue.
