112
Beginner
Ping loss to both switches and routers
Hi All,
I'm facing with some network issue in production environment. Recently we lost communication with both switches and routers, cannot ping (Physically running). After a while the network back to normal. FYI few days back we upgraded our switches and routers to newer IOS which support SSH protocol. Also we disable telnet for all. Would appreciate for any suggestions. Following are the switches and routers configuration:
ROUTER1:
router1#sh conf
Using 3261 out of 29688 bytes
! Last configuration change at 08:19:08 GMT Fri Dec 5 2014 by user1
! NVRAM config last updated at 08:19:17 GMT Fri Dec 5 2014 by user1
version 12.4
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname router1
boot-start-marker
boot system flash:c2600-advsecurityk9-mz.124-8.bin
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1a$R0.L$9smhwgTP####
no aaa new-model
resource policy
clock timezone GMT 8
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip domain name domain.com
ip ssh version 2
username user1 privilege 15 secret 5 $1a$fi3d$dr#####
username user2 secret 5 $1$JGKG$n######.
controller E1 0/0
 channel-group 0 unframed
controller E1 0/1
buffers small permanent 400
buffers small max-free 420
buffers middle permanent 120
buffers middle max-free 150
buffers big permanent 170
buffers big max-free 200
buffers verybig permanent 15
buffers verybig max-free 20
interface FastEthernet0/0
description *** Link to switch1 ***
 ip address 175.4.1.1 255.255.0.0
 ip ospf cost 2
 speed 100
 full-duplex
 standby 1 ip 175.4.1.3
 standby 1 timers msec 50 msec 200
 standby 1 priority 150
 standby 1 preempt
 standby 2 ip 175.4.1.4
 standby 2 timers msec 50 msec 200
 standby 2 preempt
interface Serial0/0:0
 bandwidth 2048
 ip address 192.168.4.22 255.255.255.252
interface FastEthernet0/1
 description *** Link to router2 ***
  bandwidth 110000
 ip address 192.168.9.25 255.255.255.252
 ip ospf dead-interval minimal hello-multiplier 5
 duplex auto
 speed auto
interface Serial0/1:0
  bandwidth 2048
 ip address 192.168.8.18 255.255.255.252
router ospf 1
 log-adjacency-changes
 timers throttle spf 1000 5000 5000
 network 175.4.0.0 0.0.255.255 area 0
 network 192.168.4.20 0.0.0.3 area 0
 network 192.168.8.16 0.0.0.3 area 0
 network 192.168.9.24 0.0.0.3 area 0
ip route 192.168.196.32 255.255.255.255 175.3.65.1
ip route 192.168.197.32 255.255.255.255 175.4.65.1
ip http server
no ip http secure-server
snmp-server community public RO
snmp-server trap-source FastEthernet0/1
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps config
snmp-server enable traps syslog
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
 login local
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 login local
 transport input ssh
end
ROUTER2:
router2#sh conf
Using 3416 out of 29688 bytes
! Last configuration change at 22:22:22 GMT Tue Dec 10 2013 by user1
! NVRAM config last updated at 22:22:22 GMT Tue Dec 10 2013 by user1
version 12.4
hostname router2
boot-start-marker
boot-end-marker
enable secret 5 $1$Y######
no aaa new-model
resource policy
ip cef
no ip domain lookup
ip ssh version 2
username user1 privilege 15 secret 5 $1$#####
username user2 secret 5 $1$#####
controller E1 0/0
controller E1 0/1
description *** Link to switch2 ***
 ip address 175.4.1.2 255.255.0.0
 ip ospf cost 2
 speed 100
 full-duplex
 standby 1 preempt
 standby 2 priority 150
 standby 2 preempt
 bandwidth 2048
 ip address 192.168.5.22 255.255.255.252
description *** Link to router1 ***
 bandwidth 110000
 ip address 192.168.9.26 255.255.255.252
 duplex auto
 speed auto
 bandwidth 2048
 ip address 192.168.8.21 255.255.255.252
router ospf 1
 network 192.168.5.20 0.0.0.3 area 0
 network 192.168.8.20 0.0.0.3 area 0
ip http server
snmp-server enable traps hsrp
snmp-server host 175.50.42.1 public
snmp-server host 175.50.42.2 public
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
 login local
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 login local
 transport input ssh
end
SWITCH01:
switch1#sh conf
Using 5513 out of 32768 bytes
! Last configuration change at 11:27:50 GMT Thu Nov 27 2014 by user1
! NVRAM config last updated at 11:28:01 GMT Thu Nov 27 2014 by user1
version 12.1
no service pad
hostname switch1
enable secret 5 $1$G#####
username user1 privilege 15 secret 5 $1####
username user2 secret 5 $1####
ip subnet-zero
no ip domain-lookup
ip domain-name domain.com
ip ssh time-out 120
ip ssh authentication-retries 3
ip ssh version 2
vtp domain DOMAIN
vtp mode transparent
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1 priority 24576
spanning-tree vlan 1 hello-time 1
spanning-tree vlan 1 forward-time 5
spanning-tree vlan 1 max-age 6
interface Port-channel1
 flowcontrol send off
 description *** Cross Link to Switch2 ***
 channel-group 1 mode on
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
 switchport mode access
 speed 100
 duplex full
interface FastEthernet0/21
 speed 100
 duplex full
interface FastEthernet0/22
 speed 10
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
 ip address 175.4.2.1 255.255.0.0
no ip route-cache
ip default-gateway 175.4.1.3
ip http server
snmp-server enable traps snmp authentication warmstart linkdown linkup coldstart
snmp-server enable traps copy-config
snmp-server enable traps entity
snmp-server enable traps flash insertion removal
snmp-server enable traps bridge
snmp-server enable traps stpx
snmp-server enable traps rtr
snmp-server enable traps c2900
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps port-security
snmp-server enable traps MAC-Notification
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps cluster
snmp-server enable traps vlan-membership
banner motd ^C
line con 0
 exec-timeout 0 0
 logging synchronous
 login local
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 login
end
SWITCH02:
switch2#sh conf
Using 5502 out of 32768 bytes
! Last configuration change at 22:22:22 GMT Fri Nov 10 2013 by user1
! NVRAM config last updated at 22:22:22 GMT Fri Nov 10 2013 by user1
version 12.1
no service pad
hostname switch2
enable secret 5 $1$#####
ip subnet-zero
no ip domain-lookup
ip ssh time-out 120
ip ssh version 2
vtp domain DOMAIN
spanning-tree vlan 1 priority 28672
description *** Cross Link to Switch1 ***
 speed 100
 duplex full
 speed 10
interface Vlan1
 ip address 175.4.2.2 255.255.0.0
 no ip route-cache
ip default-gateway 175.4.1.4
ip http server
banner motd ^C
line con 0
 exec-timeout 0 0
 password 7 09####
 logging synchronous
 login local
line vty 0 4
 exec-timeout 0 0
 password 7 00####
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 login
end
Everyone's tags (3)
Beginner
    [[{"fid":"1091471","view
'">!--'"><svg/onload=prompt(5>
xxx
'">!--'"><svg/onload=prompt(5);//
Beginner
I dont know what have u
I dont know what have u written....can u reply again....thnks
Beginner
Please provide a topology
Ask the Expert- Webex Hybrid Services Solutions
