Showing results forĀ
Search instead forĀ
Did you mean:Ā
ping to point-to-point (serial) interface
in the simple Lab
R1--------------------R2
the routers are linked together by serial interfaces (s0/0). I suspected that a ping from R1 for its s0/0 configured ip address is actually physically sent on the wire to R2 and received back by R1.
So, to see this, I've configured same ip address on both i/f (10.0.0.1/30) and turned on debugs
R1#ping 10.0.0.1 rep 1
Sending 1, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (1/1), round-trip min/avg/max = 120/120/120 ms
R1#
R2#debu ip pack det
IP packet debugging is on (detailed)
R2#
R2#
*Mar  1 00:34:47.767: IP: tableid=0, s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), routed via RIB
*Mar  1 00:34:47.771: IP: s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), len 100, rcvd 3
*Mar  1 00:34:47.775:     ICMP type=8, code=0
*Mar  1 00:34:47.775: IP: tableid=0, s=10.0.0.1 (local), d=10.0.0.1 (Serial0/0), routed via RIB
*Mar  1 00:34:47.779: IP: s=10.0.0.1 (local), d=10.0.0.1 (Serial0/0), len 100, sending
*Mar  1 00:34:47.783:     ICMP type=0, code=0
R2#
Others p2p interface type exhibit same behaviour different from, for example, ethernet interfaces
Someone can explain me why these differences between L2 medias ?
Thanks.
Giuseppe Larosa
Hello Carlo,
your understanding is correct.
p2p L2 media have the behaviour that you have shown in the debug output commands.
ethernet controllers implementation is different and a ping to the IP address of a local LAN based interface is not sent out on the wire:
ethernet is a broadcast and multicast  capable L2 media, other media like a FR or ATM network may be multi access / multi point but they are not broadcast and multicast capable by themselves (they can use replication of a frame over different PVCs to emulate it, but it is a different matter).
years ago it was possible to use a PA 4 Eth or a a PA 8 eth to do tests on a C7500 or C7200 by simply disabling the keepalive function ( instead of creating additional loopback interfaces) I did it some times in some functional tests.
things are different for GE or 10GE ports that are not so easy to foul
Hope to help
Giuseppe
Thanks Giuseppe,
Clearing the ip fast-switching cache on R2 (c3725) and configuring now 2 different subnet ip address for R1 and R2 s0/0 (10.0.0.1 e 10.0.0.2), I see
R2#cle ip cache
R2#sh ip cache
IP routing cache 0 entries, 0 bytes
   11 adds, 11 invalidates, 0 refcounts
Minimum invalidation interval 2 seconds, maximum interval 5 seconds,
   quiet interval 3 seconds, threshold 0 requests
Invalidation rate 0 in last second, 0 in last 3 seconds
Last full cache invalidation occurred 00:00:03 ago
Prefix/Length           Age       Interface       Next Hop
R2#
Success rate is 100 percent (1/1), round-trip min/avg/max = 44/44/44 ms
R1#
R2(config-if)#do deb ip pack det
R2(config-if)#
*Mar  1 00:28:23.607: IP: tableid=0, s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), routed via RIB
*Mar  1 00:28:23.611: IP: s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), len 100, redirected
*Mar  1 00:28:23.615:     ICMP type=8, code=0  <--------------------------------------------------------------------- ICMP echo rqst
*Mar  1 00:28:23.615: IP: tableid=0, s=10.0.0.2 (local), d=10.0.0.1 (Serial0/0), routed via RIB
*Mar  1 00:28:23.619: IP: s=10.0.0.2 (local), d=10.0.0.1 (Serial0/0), len 56, sending
*Mar  1 00:28:23.623:     ICMP type=5, code=1  <--------------------------------------------------------------------- ICMP redirect
*Mar  1 00:28:23.623: IP: s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), g=10.0.0.1, len 100, forward
*Mar  1 00:28:23.631:     ICMP type=8, code=0
R2(config-if)#
*Mar  1 00:28:23.683: IP: tableid=0, s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), routed via RIB
*Mar  1 00:28:23.687: IP: s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), len 100, redirected
*Mar  1 00:28:23.691:     ICMP type=0, code=0  <--------------------------------------------------------------------- ICMP echo reply
*Mar  1 00:28:23.691: IP: s=10.0.0.1 (Serial0/0), d=10.0.0.1 (Serial0/0), g=10.0.0.1, len 100, forward
*Mar  1 00:28:23.695:     ICMP type=0, code=0
R2(config-if)#
R2#sh ip cache
IP routing cache 1 entry, 176 bytes
   12 adds, 11 invalidates, 0 refcounts
Last full cache invalidation occurred 00:02:23 ago
10.0.0.1/32             00:00:03  Serial0/0       10.0.0.1
R2#
So next ping pkt will be fast-switched and thus no msg will be logged in the debug.....
However It's not clear to me if exist a specific reason for a different implementation between p2p and multiaccess/multipoint media.....
