ping u.u.u ??
briansciarra
Hey,
I recently got fios at a branch to facilitate a backup circuit (dmvpn over bgp)
I am plugging my cisco 2911 directly into the Ethernet port of the ONT, which looks like a modem that converts fiber to ethernet
When I do that, when I try to ping the interface on my router that is plugged into the ONT, and I get a response 'U.U.U'
Not sure what to make of this
I can ping my gateway so that's promising
If I pull the cable out of the interface, I can ping the interface but not my gateway.
I can't failover test for a couple days but just curious does anyone know what U.U.U means?  I'm ssh'd into the router that I'm pinging the interface of so it should just work.
Thanks!
Titolalmostapha
Chaque « U » signifie qu’un paquet « destination inaccessible » a été recu.
U : Unreachable
Agree that the U indicates Unreachable. The reason that there are 3 U and not 5 U is due to rate limiting on the ICMP responses.
Rick
Rick
and here is some more info to understand u.u.u pattern
http://packetlife.net/blog/2008/may/27/dissecting-unreachable-ping-response/
Best Regards Please rate all helpful posts and close solved questions
