PIX 515 and Vlan Routing with Catalyst 2950
Hello, I am running a Cisco Pix 515 firewall with the latest IOS
and a Cisco Catalyst Switch 2950, ​​with the latest IOS. Port 1 is on the switch as a trunk for Vlan 10 and 20. Port 2 are VLAN10 Port 6 VLAN 20 VLAN10 = 192.168.10.0 Client 192.168.10.10 255.255.255.0 VLAN20 = 192.168.20.0 Client 192.168.20.20 255.255.255.0 On the PIX, the external interface is connected to my FritzBox.
IP of the Outside Interface on the Pix 192.168.178.2 255.255.255.0 Route: Interface Outside 0.0.0.0 0.0.0.0 192.168.178.1 There are 2 subinterfaces on interface 2 that are handled. On the Pix 1. SubInt = 192.168.10.1 255.255.255.0 2. SubInt = 192.168.20.1 255.255.255.0 Nat rules were heard. Both clients, one in the vlan10 and the other in the vlan20,
can access the Internet via the PIX Peer NAT. Unfortunately, the ping between the two clients does not work. Rules were also taken into account. Windows Firewall is switched off
Switch Config:
Switch#show running-config
Building configuration...
Current configuration : 1550 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 switchport trunk allowed vlan 10,20
 switchport mode trunk
interface FastEthernet0/2
 switchport access vlan 10
 switchport mode access
 spanning-tree portfast
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
 switchport access vlan 20
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan10
 no ip address
interface Vlan20
no ip address
ip http server
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Switch#
PIX Config:
: Saved
PIX Version 8.0(4)23
hostname pixfirewall
domain-name PIX
enable password axb3wREqWJcNiySG encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
interface Ethernet0
 nameif outside
 security-level 0
 ip address 192.168.178.2 255.255.255.0
 ospf cost 10
interface Ethernet1
 shutdown
 nameif inside
 security-level 100
 no ip address
 ospf cost 10
interface Ethernet2
 no nameif
 security-level 100
 no ip address
interface Ethernet2.10
 vlan 10
 nameif Vlan10
 security-level 100
 ip address 192.168.10.1 255.255.255.0
interface Ethernet2.20
 vlan 20
 nameif Vlan20
 security-level 100
 ip address 192.168.20.1 255.255.255.0
interface Ethernet3
 shutdown
 no nameif
 no security-level
 no ip address
interface Ethernet4
 shutdown
 no nameif
 no security-level
 no ip address
interface Ethernet5
 shutdown
 no nameif
 no security-level
 no ip address
ftp mode passive
dns server-group DefaultDNS
 domain-name PIX
access-list outside_access_in extended permit ip any any
access-list SubVLan20_access_in extended permit ip any any
access-list SubVLan20_access_in extended permit icmp any any
access-list SubVlan10_access_in extended permit ip any any
access-list SubVlan10_access_in extended permit icmp any any
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
access-list Vlan20_access_in extended permit ip any any
access-list Vlan20_access_in_1 extended permit ip any any
access-list Vlan20_access_in_1 extended permit icmp any any
access-list Vlan10_access_in extended permit ip any any
access-list Vlan10_access_in extended permit icmp any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu Vlan10 1500
mtu Vlan20 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 192.168.178.100-192.168.178.110 netmask 255.255.255.0
global (outside) 1 192.168.178.99 netmask 255.255.255.0
nat (Vlan10) 1 192.168.10.0 255.255.255.0
nat (Vlan20) 1 192.168.20.0 255.255.255.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group Vlan10_access_in in interface Vlan10
access-group Vlan20_access_in_1 in interface Vlan20
route outside 0.0.0.0 0.0.0.0 192.168.178.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.10.10 255.255.255.255 Vlan10
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.10.10 255.255.255.255 Vlan10
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username runner password oSxq6Zotq9senXtp encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:cd5dbfe8caa446ca873496c96dedab1c
: end
 Could anyone help me, please
Harold Ritter
Hi Christian,
You can use the following command to allow traffic to flow between two interfaces (sub interfaces) with the same security level.
same-security-traffic permit inter-interface
Hey Harold. Thanks for your Answer.
Unfortunately that doesn't work.
I cant ping.
Please post updated version of running config. When you attempt to ping from one inside host to the other please check the logs on the PIX and look for any messages that relate to either of these hosts.
Rick
