please i need help DHCP Snooping
ashraf dawood
Hii
My Friends
I have Cisco router 2801 and i need to implement DHCP Snooping on it But the command
R1(config)# ip dhcp snooping
not accepted by the router and not recognized  by it Ido
R1# show version
and the result is
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.4(16a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 10-Sep-07 10:27 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
HQ-Router uptime is 1 minute
System image file is "flash:c2801-ipbase-mz.124-16a.bin"
Cisco 2801 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ114613E5
2 FastEthernet interfaces
2 Low-speed serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
the IOS for this router is C2801-IPBASE-M i tried to make Upgrade for his ios but i cannot find the correct one so any one can help me plzzz
Mark Malone
Your image does not support snooping looking at the feature navigator
as well that image is so old its not even listed anymore with cisco its deferred state by the look of it , the only image left in that train is 12.4 19a to donwload , all other images you cant support as you don't have enough ram only 128 , all new images are 192 or more up to 256
19a does not support snooping either way to old , you need more ram and move to a newer image that supports snooping , you can check on the feature navigator below
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
https://software.cisco.com/download/release.html?mdfid=279316777&softwareid=280805680&release=15.1.4M4
