12-19-2007 01:20 AM - edited 03-03-2019 07:59 PM
Hi friends,
I had installed a 4507 with 2 power supply, and 2 module PoE WS-X4248-rj45V. I had connected a sony PoE camera but nothing work, the PoE don't work. Either in a 3750 PoE works fine with the same camera! what can be the problem?
12-19-2007 01:26 AM
can you do a debug ilpower events and connect the camera and post the results along with the show environment?
Narayan
12-19-2007 06:39 AM
12-19-2007 06:49 AM
PWR-C45-1400AC is a data only power supply
You need a power supply that is both Data and POE)
Have a look here for the power suppkies that support PoE
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet09186a00801f3dd9.html
Narayan
12-19-2007 08:48 AM
thanks a lot!
