point to point connectivity problem
Dear friends,
I am using Cisco 1841 router for point to point connectivity  between 3 locations.
Site A: 192.168.1.0/24
Site  B: 192.168.50.0/24
Site c: 192.168.100.0/24
Site A includes a server (windows 2008 server 64 bit). We share a software from this server to all sites. This server use foxpro platform. I can access the server from A  site properly but it is creating a problem within other two sites like slow connectivity and slow printing issues. The page takes 30 min to open .
Site A cisco 1841 configuation are as follows:
Bopodi_Router>en
Password:
Bopodi_Router#sh tun
% Incomplete command.
Bopodi_Router#sh run
Building configuration...
Current configuration : 3463 bytes
version 12.4
hostname Bopodi_Router
boot-start-marker
boot-end-marker
logging buffered 51200 warning
enable secret 5 $1$UwDx$iDrXjPyaa91w5EfMDUNbD.
no aaa new-model
ip cef
ip domain name yourdomain.com
ip address-pool local
username cisco password 0 cisco
archive
log config
hidekeys
interface FastEthernet0/0
description ****site B****
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description ****Site A
ip address 11.0.0.1 255.255.255.0
duplex auto
speed auto
description ***Site A****
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 192.168.1.0 255.255.255.0 192.168.50.0
ip route 192.168.1.0 255.255.255.0 192.168.100.0
ip route 192.168.1.0 255.255.255.0 192.168.2.0
ip route 192.168.50.0 255.255.255.0 FastEthernet0/0
ip route 192.168.100.0 255.255.255.0 FastEthernet0/1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
thanks in advance..........
cadet alain
1) never point a static route towards a multiaccess interface but instead towards next hop
2) the the 3  static routes to 192.168.1.0 can be deleted because this subnet is directly connected via Vlan1 interface.
Regards.
Alain.
Also: have you tried setting the ip mtu setting lower on interface towards location A on location B and C? Perhaps also try adjusting the tcp mss size?
