policing
bellocarico
What is the difference between these 3 commands?
R1(config-map)police XXX
R1(config-map)police cir XXX
R1(config-map)police rate XXX
Thanks to read.
royalblues
Level 10
Level 10
from the command lookup table
police
To configure traffic policing, use the police command in policy-map class configuration mode or policy-map class police configuration mode. To remove traffic policing from the configuration, use the no form of this command.
police bps [burst-normal] [burst-max] conform-action action exceed-action action [violate-action action]
police (two rates)
To configure traffic policing using two rates, the committed information rate (CIR) and the peak information rate (PIR), use the police command in policy-map configuration mode. To remove two-rate traffic policing from the configuration, use the no form of this command.
police cir cir [bc conform-burst] pir pir [be peak-burst] [conform-action action [exceed-action action [violate-action action]]]
police rate (control-plane)
To configure traffic policing for traffic that is destined for the control plane, use the police rate command in policy-map class configuration mode. To remove traffic policing from the configuration, use the no form of this command.
Syntax for Packets Per Seconds
police rate units pps [burst burst-in-packets packets] [peak-rate peak-rate-in-pps pps] [pack-burst peak-burst-in-packets packets]
HTH, rate if it does
Narayan
