Policy-Map class creates a dscp default queue inside the Policy/Class?? [Not the default Class]
_|brt.drml|_
I'm running test with new policy-maps on same hardware and same IOS version. Should be all the same configuration at the basis. When running test with the WRED configuration. Each class-map (INTERACT/TRANSACT/BULK) created also a 'default' queue.
Do not find the reason.. any idea?
show policy-map interface xx :
        Class-map: CM_QOS_C_INTERACT (match-any)
          435972 packets, 171050070 bytes
          5 minute offered rate 239000 bps, drop rate 0000 bps
          Match: qos-group 31
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: qos-group 32
            412960 packets, 168111830 bytes
            5 minute rate 233000 bps
          Match:  dscp af31 (26) af32 (28) af33 (30)
            23012 packets, 2938240 bytes
            5 minute rate 3000 bps
          Queueing
          queue limit 400 packets
          (queue depth/total drops/no-buffer drops) 3/71/0
          (pkts output/bytes output) 431592/186310752
          bandwidth remaining 60%
            Exp-weight-constant: 9 (1/512)
            Mean queue depth: 0 packets
            dscp       Transmitted         Random drop      Tail drop          Minimum        Maximum     Mark
                    pkts/bytes            pkts/bytes       pkts/bytes          thresh         thresh     prob
            default     8030/11407044       10/13380         61/86906             20            40  1/10
            af31          85/12830           0/0              0/0                320           400  1/10
            af32      423477/174890878       0/0              0/0                280           400  1/10
            af33           0/0               0/0              0/0                240           400  1/10
And it does match traffic. The tagging is ok, as the correct service falls in the correct queue. However, why is the 'default' queue created?
6 Replies 6
Giuseppe Larosa
Hello @_|brt.drml|_ ,
you have enabled WRED for this class-map and this may be the reason why a queue for DSCP default has been created.
However, the class-map should process only packets :
So there should not be any match in the DSCP default queue unless you are using also a policer that marks down non conforming packets.
Hope to help
Giuseppe
Joseph W. Doherty
In your posting, there's no default queue, there's only one queue, the class queue.
When DSCP WRED is enabled, all the possible DSCP values have WRED default parameters (or at least that's how it used to be).
What might be happening here, only DSCP values that override the defaults and/or are seeing their corresponding DSCP values, might be shown with this command.  (I recall [?] this command, on older equipment, showed all the DSCP WRED settings.)
What's interesting in your stats, DSCP BE is showing "hits", maybe matching in qos-group 32.
_|brt.drml|_
Just to repeat, each class has that 'default' queue enabled...
I'll have a look if there is a difference with the [?] as suggested commands between both systems.
The funny thing, items are correctly hit by the ACL, are placed in the correct queue. However, the 'default' queue in each class-map is also getting 'hits'.
Each class-map 'something-something' with this default queue has different 'stats'. So they are all different.
Weird stuff.
Thank you for the answers. If I find something, then I'll post it.
"Just to repeat, each class has that 'default' queue enabled... "
Again, also to repeat (for your class, as you posted [as there's no FQ is enabled in class]) there's only one queue per class (in non-LLQ policy classes).
What you're seeing is how WRED deals with BE marked packets.
Yes, there's the question of why you're getting hits on those.  Assuming BE marked packets won't match any of the class rule's, there shouldn't be any in that class.  Also again, since you didn't post all the supporting parts of the config for this policy, cannot say if that's happening.  Also, possible, stats were from earlier version of class-map rules.
_|brt.drml|_
This is the Policy_Map. It has NV 'NO Video' expected on that line. Legacy stuff that is disappearing.
The 'Class DEFAULT' is exactly the same as the Cisco Default, also Legacy : Can be seen as the scavenger class.
policy-map PM_QOS_C_NV-85-5-0-10
 class CM_QOS_C_VOICE
  priority level 1
  police cir percent 9
 class CM_QOS_C_ROUTING
  bandwidth remaining percent 2
 class CM_QOS_C_NETMGT
  set mpls experimental topmost 7
 class CM_QOS_C_CALLSIG
 class CM_QOS_C_INTERACT
  bandwidth remaining percent 60
  queue-limit 400 packets
  random-detect dscp-based
  random-detect dscp 26 320 400 10
  random-detect dscp 28 280 400 10
  random-detect dscp 30 240 400 10
 class CM_QOS_C_TRANSACT
  bandwidth remaining percent 10
  random-detect dscp 18 320 400 10
  random-detect dscp 20 280 400 10
  random-detect dscp 22 240 400 10
 class CM_QOS_C_BULK
  bandwidth remaining percent 8
  random-detect dscp 10 320 400 10
  random-detect dscp 12 280 400 10
  random-detect dscp 14 240 400 10
 class CM_QOS_C_HIGHNET
  bandwidth remaining percent 5
  random-detect
  random-detect precedence 0 25 64 10
  random-detect precedence 1 30 64 10
  random-detect precedence 2 35 64 10
  random-detect precedence 3 40 64 10
  random-detect precedence 4 45 64 10
  random-detect precedence 5 50 64 10
  random-detect precedence 6 55 64 10
  random-detect precedence 7 60 64 10
 class CM_QOS_C_PUBNET
  random-detect
 class CM_QOS_C_DEFAULT
  fair-queue
  queue-limit 1000 packets
 class class-default
  fair-queue
  random-detect
  random-detect precedence 0 60 64 1
  police cir percent 1
The marker at the VLAN:
policy-map PM_QOS_M_CORPNET_D
 class CM_QOS_P_VOICE
  set ip dscp ef
  set mpls experimental imposition 5
  set qos-group 50
 class CM_QOS_P_VIDEO
  set ip dscp af41
  set mpls experimental imposition 4
  set qos-group 40
 class CM_QOS_M_VOICE
  set ip dscp ef
  set qos-group 50
 class CM_QOS_P_NETMGT
  set ip dscp cs2
  set mpls experimental imposition 7
  set qos-group 29
 class CM_QOS_P_BULK
  set ip dscp af11
  set mpls experimental imposition 0
  set qos-group 11
 class CM_QOS_P_TRANSACT
  set ip dscp af21
  set qos-group 21
 class CM_QOS_P_INTERACT
  set ip dscp af32
  set qos-group 32
 class CM_QOS_P_PRIORITY
  set qos-group 31
  set ip dscp af31
 class class-default
  set ip dscp default
  set qos-group 0
Example of the marking 'match'-any classes:
class-map match-any CM_QOS_P_TRANSACT
 match protocol ms-lync
 match protocol smtp
 match protocol mapi
 match access-group name ACL_IP_DST_DMZ
 match access-group name ACL_IP_SRC_DMZ
On the outgoing Policy-Map the Default Class matches on this:
class-map match-any CM_QOS_C_DEFAULT
  description Class Map for Policing Identification of Default Unclassified Traffic
 match dscp default
 match mpls experimental topmost 0
 match qos-group 0
 If you need something else for the assessment, mail me. I can't understand this. As I have another more recent configuration on the same hardware. The only change is that I updated the 'Namings' according the Cisco QoS book.
I would expect that the BE fall in the class-map match any DEFAULT
_|brt.drml|_
Read over it,, indeed some extra context would be helpful.
The OUT policy map on the tunnel (That is the child of the parenet 'shaper')
  priority level 1
 class CM_QOS_C_BULK
  random-detect
  random-detect
  fair-queue
 class class-default
  fair-queue
  random-detect
The marking happens on the VLAN; it matches on standard protocols or ACL's.
if I do a 'show policy-map' then I can see the wred configuration in a table. This is exactly the same then with the other router.
#sh policy-map PM_QOS_C_NV-85-5-0-10
  Policy Map PM_QOS_C_NV-85-5-0-10
    Class CM_QOS_C_VOICE
      priority level 1
       conform-action transmit
       exceed-action drop
    Class CM_QOS_C_ROUTING
      bandwidth remaining 2 (%)
    Class CM_QOS_C_NETMGT
    Class CM_QOS_C_CALLSIG
    Class CM_QOS_C_INTERACT
      bandwidth remaining 60 (%)
       packet-based wred, exponential weight 9
      dscp    min-threshold    max-threshold    mark-probablity
      af31 (26)     320              400              1/10
      af32 (28)     280              400              1/10
      af33 (30)     240              400              1/10
      default (0)   -                -                1/10
So they all have that default queue inside the class....Except in this router it is shown inside the 'sh policy-map interface tunnel' as shown in the beginning. With packets inside it.
