11-27-2023
07:53 AM
- last edited on
11-29-2023
09:57 AM
by
Translator
Hello, I have the configuration below on an old Router IOS 12.x and I want to migrate it to an IOS 17.x, but the
drop
action at the end is not accepted as a command on this IOS. I have seen that I can use the
police cir 8000 bc 1500 be 1500 conform-action drop exceed-action drop violate-action drop
command, but I am not sure if there is another way to do it or if this way will be working as expected and if the values I am using here are the right ones.
class-map match-all DROP
match any
class-map match-all ISAKMP
match protocol isakmp
class-map match-all IPSEC
match protocol ipsec
policy-map NBAR2
class ISAKMP
class IPSEC
class protocolos
class DROP
drop
Solved! Go to Solution.
11-27-2023 11:58 AM
11-27-2023 08:39 AM
Can you post the error you getting while applying the config on the device, what device is this ?
check below guide :
11-27-2023
08:45 AM
- last edited on
11-29-2023
09:59 AM
by
Translator
drop does not exist...
R1(config-pmap-c)#class DROP
R1(config-pmap-c)#drop
% Invalid input detected at '^' marker.
11-27-2023
08:39 AM
- last edited on
11-29-2023
10:01 AM
by
Translator
Don't have a real platform, with that IOS to try your config snippet on, by on CML running an IOSv
Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6, RELEASE SOFTWARE (fc1)
got:
inserthostname-here#conf t
Enter configuration commands, one per line. End with CNTL/Z.
inserthostname-here(config)#class-map match-all DROP
inserthostname-here(config-cmap)# match any
inserthostname-here(config-cmap)#class-map match-all ISAKMP
inserthostname-here(config-cmap)# match protocol isakmp
inserthostname-here(config-cmap)#class-map match-all IPSEC
inserthostname-here(config-cmap)# match protocol ipsec
inserthostname-here(config-cmap)#policy-map NBAR2
inserthostname-here(config-pmap)# class ISAKMP
inserthostname-here(config-pmap-c)# class IPSEC
inserthostname-here(config-pmap-c)# class protocolos
class map protocolos not configured
inserthostname-here(config-pmap)# class DROP
inserthostname-here(config-pmap-c)# drop
inserthostname-here(config-pmap-c)#end
inserthostname-here#sh run | beg -map
match any
policy-map NBAR2
class ISAKMP
class IPSEC
class DROP
drop
BTW, as it appears you wish to drop all unrecognized traffic, you might try replacing class DROP with (build-in) class-default.
i.e.:class-map match-all DROPmatch any
policy-map NBAR2
class ISAKMP
class IPSEC
class protocolos
classDROPclass-default
drop
11-27-2023
08:45 AM
- last edited on
11-29-2023
10:05 AM
by
Translator
R1(config-pmap-c)#class class-default
11-27-2023
09:15 AM
- last edited on
11-29-2023
10:04 AM
by
Translator
Well, that's not totally unexpected. Class-default being different was a long shot (although it has been different in the past).
As @balaji.bandi asked, what's the specific device? Specific IOS might be useful to know to.
What does "?" mark show for command options under policy map class?
Could you list "?" options for that
11-27-2023
09:33 AM
- last edited on
11-29-2023
10:07 AM
by
Translator
It is a CAT 8300 version 17.9.3a but it has the same behavior as the C7200 version 15.2(4)S4:
R1(config-pmap-c)#?
Policy-map class configuration commands:
bandwidth Bandwidth
exit Exit from QoS class action configuration mode
fair-queue Enable Flow-based Fair Queuing in this Class
netflow-sampler NetFlow action
no Negate or set default values of a command
police Police
priority Strict Scheduling Priority for this Class
queue-limit Queue Max Threshold for Tail Drop
random-detect Enable Random Early Detection as drop policy
service-policy Configure QoS Service Policy
set Set QoS values
shape Traffic Shaping
R1(config-pmap-c)#
11-27-2023 09:55 AM
Specific IOS variant and/or feature licenses being used? (In the past, I've been surprised by lack of some features in IOS images like Voice or Service Provider.)
11-27-2023 10:33 AM
hi friend
add one class under policy then check dont use multi.
try this and update me
MHM
11-27-2023
11:34 AM
- last edited on
11-29-2023
10:08 AM
by
Translator
I do not know if this is what you want. I deleted the policy and then I started to create it again:
R1(config-pmap-c)#policy-map NBAR2
R1(config-pmap)#class DROP
R1(config-pmap-c)#?
bandwidth Bandwidth
police Police
set Set QoS values
R1(config-pmap-c)#
11-27-2023 11:38 AM - edited 11-27-2023 11:39 AM
Then select
police
Then add low or none rate and violation drop.
MHM
11-27-2023
11:42 AM
- last edited on
11-29-2023
10:14 AM
by
Translator
I do not have the low or none rate option
R1(config-pmap-c)#police ?
<8000-2000000000> Target Bit Rate (bIts per second) (postfix k, m, g
optional; decimal point allo
cir Committed information rate
rate Specify police rate, PCR for hierarchical policies or SCR
for single-level ATM 4.0 policer policies
R1(config-pmap-c)#police ra
R1(config-pmap-c)#police rate ?
<1-2000000000> Rate value (postfix k, m, g optional; decimal point allowed)
percent % of interface bandwidth for rate
11-27-2023 11:58 AM
Police 8000 then select violation or exceed.
MHM
11-27-2023 12:02 PM
Ok, great. Just a question, is there any reason to use 8000 or it's just because that is the lowest rate?
I will test it tomorrow on my customers Router and as soon I check it I will let you know the result.
11-27-2023 12:15 PM
Your Q @Joseph W. Doherty can answer you.
He is king of QoS.
The different between cir and rate and more the king of QoS can help you.
MHM
