Port Channel 1 Interface down
Hi Team I have 1 Switch in office & another in data centre , Connected over Port channel. In port channel 2 switch interface each side is added. if 1 interface in either side will down  then port channel will be down? .
pman
Enthusiast
Enthusiast
No, for the port channel to be down then the 2 ports on each side must be down
Ok Got it . both port should be down on either side  then only Port channel will be down .  If one interface down then other interface will carry traffic
Hello
Correct..
Kind Regards
Paul
MHM Cisco World
Advisor
Advisor
if you config min-link and this interface make the number of link less than this value the port-channel will be down.
check this point.
