01-03-2018 06:51 AM - edited 03-05-2019 09:42 AM
Hi All,
What will be the consequences if we create Ether Channel/Port channel on One side and leave other side Default ?
What happens if we use PAGP/LACP and Static "ON" ?
Prasanna Kumar Desireddy
01-03-2018 02:17 PM
Hello
@D Prasanna Kumar Reddy wrote:
Hi All,
Why would you want to? - Basically no aggregation will form as for the etherchannel to establish both side need to configured
res
Paul
01-04-2018 08:57 AM
I am not really wanted to do . . I wanted to know what if we delete one side PO by error ?
01-04-2018 09:14 AM - edited 01-04-2018 09:18 AM
Hello
The interfaces would then be treated individually and depending on if it was a L2 or L3 depends on the effect it has - naturally a L3 deletion would possibly incurr a lost route and depletion of aggregate bandwidth.
L2 - Spanning- tree would not be a single instance or cost anymore but would result in it being again applied on the individual interfaces
Res
Paul
01-03-2018 03:42 PM - edited 01-03-2018 03:43 PM
I agree with Paul, also check the following picture it can be useful:
