port forwarding
hello i need help pls
I have windows server located in the school  on my privet lan
and i want to connect this server from my house via remote desktop function
the External port number is 10015 its alredy opend inde router internal port 3398
Bublic ip adress 81.15.15.200 privert ip adres of the LAN 192.168.0.2
So what command shoud i add hier?
The confiegration of my privet network as below
conf t
ip dhcp pool vlan 1
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
dns-server 8.8.8.8
exit
interface FastEthernet4
ip address dhcp
ip nat outside
no shutdown
exit
conf t
interface Vlan1
ip address 192.168.40.1 255.255.255.0
ip nat inside
ip nat inside source list 10 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.40.3 3389 192.168.50.107 10000 extendable
ip route 0.0.0.0 0.0.0.0 192.168.50.254
exit
conf t
access-list 10 permit ip 192.168.40.0 0.0.0.255 any
access-list 10 permit any
do wr
end
thank u
Francesco Molino
I believe the public ip is on your interface Fa4?
Your private server ip is routable through 192.168.50.254?
Based on your config this host doesn't have internet access or is it going through another path?
The command would be:
ip nat inside source static tcp 192.168.0.2 3398 interf fa4 10015
Are you sure your rdp port is 3398?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
thanks
yes the server ip is routable through 192.168.50.254? my router in the school gets internet through this privet ip adres
then i will conect the server via rdp from the another netwerk lan 192.168.0.2  through de opened port 10015 in the router of lan .
and right rdp port is 3398
i will try this solution and i will send to you the feed back
thanks
But the solution won't work as your config isn't showing any interfaces in 192.168.50.0/24 subnet nor in 192.168.0.0/24.
Did you paste the whole config?
Francesco
Hello
Your lan host doesnt look correct is this a typo as it should be in the subnet your vlan 1 which is 192.168.40.0/24
Try the following:
no ip nat inside source static tcp 192.168.40.3 3389 192.168.50.107 10000 extendable
no ip route 0.0.0.0 0.0.0.0 192.168.50.254
ip nat inside source static tcp 192.168.X.2 3389 81.15.15.200 10015
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
Kind Regards
Paul
